Shift knob 65 Corvette
Received 6,943 Likes
2015 C2 of Year Finalist
unscrew it in the left motion.
The round ball unscrews lefty loosey and righty tighty
Received 1,919 Likes
^This^
It may have been on there a long time, if original.
If you can't get enough umuph to get it to break lose, I would recommend wrapping the **** in some thick rawhide, and using a set of long-handled challenlock-type pliers to try to break it loose.
That should allow more torque than necessary to break it loose. If not, maybe it's not factory? However, if the reverse interlock appears to be original, I would assume that any **** that attaches would use the same screw-off method.
As others have said, the ball just unscrews. The reverse lock out will just pull up out of the shifter handle, once you remove the ball. Watch out for the T handle spring, and the 2 split nylon bushings, inside the T (if the bushings are still there). If the bushings are missing, you may want to order a couple new ones. The bushings keep the T handle from rattling.
Jmcrae (04-16-2017)
Received 1,843 Likes
Got the ball off with a bit of force the spring came out and then I tried to pull the t handle up to remove but it only came up so far and stopped there is a bar at the top of the shifter sleeve I didn't want to yank on it because it is so small and I was afraid I would break something can you help with this problem
