[C2] Help 427 bad oil smoke on startup
That could be but I am pretty sure that I replaced the valve seals correctly. Do you think that it could be the oil rings let oil get by them when its cold, and then when it they warm up and expand they stop letting oil by them?
Thanks for all the input.
Greatly appreciated.
Beats me - but interestingly I was watching an episode of Bitching Rides the other day and they had a roadster blowing oil smoke pretty good and tried replacing valve oil seals without luck. They tore down the motor and found one cylinder where the expander/spacer for the oil ring was overlapped at the ends rather than butted up. That fixed the issue. But before they fixed it, it just kept blowing smoke - it didn't clear up as the motor warmed up. Your issue just seems to fit with some sort of a valve problem. I would bet on GTOguy's response or something similar.
If you hold your hand behind the exhaust when the engine is smoking is it a blue smoke which leaves a greasy residue on your palm or a moist, watery residue from whitish smoke. I'm not convinced the symptoms are correct yet.
The things that happen as an engine warms up are the choke opening, exhaust PS manifold heat riser opens (if there is one), engine clearances expand and idle drops.
If there is oil sitting on the heads from the engine sitting it'll get sucked down into the cylinders.....could be a crappy valve seal repair job. I wouldn't rule out a head gasket issue. It all depends on identifying what's coming out the *** end of the car. 99% certain leaves 1% in doubt..
Is it BOTH banks that are smoking?
Usually bad valve seals cause smoke immediately on startup.................not 1 full minute after. Pooled oil gets sucked into the chambers, smokes until it's burned off. This fact leaves me wondering if it's not something else, like differential expansion between aluminum heads and iron block causing leakage until both reach same temperature and equalize.
Try running the engine until the smoke starts, then shut it off, pull plugs, do leakdown again and listen for air at tailpipe (leaky exhaust valve), carburetor (leaky intake valve), and oil filler (leaky rings and/or head gasket) for each cylinder.
Since it is intermittent and not continuous, I would probably live with it until things get worse..........if they ever do.
Larry
Received 3,443 Likes
Doing a leakdown test and listening to where the blowby is coming out may help. You'll need to do all cylinders. I'm convinced you are using oil by your description of the smoke and your apparent knowledge! My gut tells me it's valve guides/seals, though. A bad oil control ring would burn oil all the time.
I have a 1967 427/435 with the factory aluminum heads. If I do a cold start, after about 1 minute I get BAD oil smoke out both sides of the exhaust. If I let it run for 3 or 4 minutes it will clean out and there is no evidence of oil burning at all after that. I replaced the valve seals which did not help the problem. Ive owned the car for about 10 years but have not driven it much. The engine looks to have been rebuilt before I got it. If I just let it sit a couple of hours and restart it,it will not smoke any. It only seems to smoke after the engine returns to room temp. Any help??
if the guides are bad enough, new seals won't fix the problem. Apparently the white teflon seals don't have a large range of flexibility. Mine has the Viton with teflon seal.
Received 3,048 Likes
C1 of Year Finalist (performance mods) 2019
It has been my experience that if it is guides or seals It will smoke on start up then clear up. If you let it idle for a while and then hit the accelerator with no load on the engine it will puff smoke again. Also if you are cruising at a steady speed for a while and then accelerate hard it will smoke again. What is happening is that the oil slipping by is building up with a small amount being burned at cruise that you don't see. When you hit it harder it burns the build up quicker so you can see it.
I think it will smoke on deceleration when engine vacuum spikes. If it smokes under load, consistently, it's rings most often.
What kind of seals did you put on? Those white Teflon seals are worthless and will definitely cause problems.
You think right. High manifold vacuum (deceleration) will suck oil past the valve guides. Easy to spot when following a car coasting down a grade or exiting the freeway. I think the OP has worn guides/seals, and that's what I would check before the next step, which is pulling the engine down.
#33
Seems I remember that BBs are hard on exhaust valve seals and guides.
Yes? No?
#34
Throw something out here; Cylinder head oil drain hole(s) restricted, causing oil to puddle and drain into cylinder(s) normally via valve seal, possibly crack.
#36
Received 3,043 Likes
St. Jude Donor '05
w/gto guy a refresh on the heads if seals doesnt get it should set you right
#38
Thanks for all of the discussion. Yes it does blow smoke out of both banks.
If I can eliminate the issue is with the rings then I will not have to pull the engine.If it is an issue with the heads,gaskets,or intake, that will make my job easier.
As I recall from doing a leak down, the noise is coming from the PVC or air breather holes in the valve covers.
I will run some of the tests discussed earlier and get back to you.
Again thanks for all the help.
#39
Hope it's not bad oil rings as I first suggested. They expand as engine warms like everything else, and could be gunked up and worn, preventing them from sealing properly when cold. That would result in leak down sounds through the crankcase.
#40
What seals did you use?
