1963 Vette will not start, interior lights do not work as well
Had a bad battery bought a new one. The battery is fully charged, when I open the door the interior lights will not operate nor will the car start, won't even turn over. If I hook up a battery charger the interior lights will operate and attempted to start the car, I get a slight whine from the starter but nothing close to even cranking over. A little bit puzzled, with a good battery I should at least get the interior lights to operate but they will only work when I hook the battery charger. Any suggestions ! If I have a bad ground somewhere would it make a difference whether the charger is hooked up or not ?
Dirty battery cables at the posts, or corroded cables internally.
Clean the insides of the lead cable end connectors with a pocket knife and put them back on the posts, first, before you buy new cables
Doug
Doug
Sounds like the "Large Red Wire" syndrome. Check the fuse box and large red wire where it connects to the firewall for corrosion.
Gary
Gary
Put a meter across the battery while someone cranks the car. If the voltage doesn't drop down to 9-10V you have corrosion or bad wiring; if it drops below that the battery is dead. The bulkhead connectors discussed above are here...
Typical green corrosion is shown in the second picture. If you disconnect the connectors to check them be damned careful when depressing the locking clips. If they are original and brittle the buggers will snap off as shown in the second picture (ask me how I know)...
Thanks, I did manage to get the connectors off with out breaking them, they appear good in shape. I can't even put a meter across as the car will not crank at all, it's a new battery and when I hook up to a charger it shows full, my old battery was not holding a charge and I was just getting the car out after a winter sleep and I was having same problem with old battery, so I figured new battery would solve the problem it appears it may be a wiring/ground issue somewhere, although it's odd if hook up the battery charger I do get the interior lights to work, so I am getting throughput of power somehow.
Thanks Doug, the cable ends are in good shape and they had no corrosion, now the cable's themselves are old so I start tracing from there.
St. Jude Donor '14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
Also, take a look under the plastic coating on the cables. Peel back some of it to see if they are corrosion free. Even a slight amount of corrosion there will cause the symptoms you're describing.
Received 3,048 Likes
C1 of Year Finalist (performance mods) 2019
Check this thread from last week for all of the possibilities.
https://www.corvetteforum.com/forums...n-t-start.html
rtruman (04-25-2017)
You still should have done the meter test... A battery charger indicates if a battery is accepting a charge, not how it acts under load. Even if a car isn't cranking you may see the voltage drop to the 2-3V range indicating a dead cell or the like. I don't ask people to do frivolous tests.
But, glad its fixed - electrical problems are the worst.
That goes without saying, so I didn't...
I gave up on my original wiring harness that had no less than 12 spliced in it (three kill switches). I gave up and rewired the whole car. What a difference that made.
If its original I would consider replacing it. Not as bad as what you might think.
Gary
