67 washer pump voltage check
My wipers work fine but I decided to fix the washers. I can't hear the bellows work so my question is; Where do I check voltage at the pump (what color wire) to see if the switch is sending the signal?
Thanks much,
rd
Thanks much,
rd
The brown wire is hot, and the blue wire grounds the pump at the switch.
Since I don't know how familiar you are with these motors, I will add that the wiper motor must be running in order for the pump to work.
Thanks so much,
rd
Actually, the motor does not have to be running to test the pump switch, only when you want to pump fluid.
Another test would be to remove the connector from the switch, take a test light and put the probe to the positive battery terminal, and put the negative alligator clip on the blue wire at the connector. Turn on the ignition switch and press the button. If the lamp lights up your switch is good.
Thanks much,
rd
