[C2] radio wiring?????
radio wiring?????
I have a 63 corvette with what looks old enough to be an original radio. I want to get it to work but the wiring info I have does not include a radio. The radio plug looks in keeping with the rest of the original wiring and I attach photos to show the radio its 3 pin plug and 2 wires at the back that look like the speaker. Any advice will be gratefully appreciated
Here is the plug from my original 63, not complicated at all...
brown-white is power
black-white is ground
remaining wire is radio light
I have an aftermarket radio and didn't want to butcher the original harness so I crimped spade lugs onto the new unit and installed them in the old connector, to wit: red is radio power, black is radio ground and green is radio light..
Soooo.....I'm not seeing the problem - you have the harness connector; you have a radio with the male spade lug receptacle, so you plug the two together ?!?
You should know you HAVE to use an original style speaker with an original radio. Meaning it must have the impedance matching transformer on it, there is only one repro worth a hoot IMO...the one in the picture.
So, don't try to use your generic Auto Boutique store 6"x 9" dash speaker!
So a radio wiring schematic would have to correspond to that model, and not the '63 or '64 model years.
Are you saying you can't plug a 67 radio straight into a 63 original harness ?
Or, that the internal radio schematics may differ by year ?
I know by comparison of a '64 radio's main printed circuit board with the '65-7 radios I have that the shape is different. I seem to recall somewhere reading that the earlier radios had an architecture that was basically AM, with FM circuits added (later '63 and '64 ?), whereas the '65-7's were FM radios with AM capability added.
