[C2] '66 327 300HP breather tube mounting postion
I'm wondering if I mounted the breather tube correctly this past weekend. The end of the tube has a hole in the top. Should it be mounted with a bolt somewhere on the intake manifold or did I do it right?
Received 1,533 Likes
That's the right place, but there is a 1/4" x 20 tpi bolt about 3" long I think that secures it to the block. I don't know the head markings or any thing like that.
Curious about your return spring on the carb, mine goes to the front of the intake near the thermostat housing.
https://www.paragoncorvette.com/p-35...g-bracket.aspx
Reeseb (05-09-2017)
Received 1,856 Likes
Photo below shows the correct vent tube with the "long bolt" (1/4"-20 by about 2-1/2" or 3") attaching its lower end to the engine block opening, and the 5/16"-18 x 1/2" bolt through the tab welded to the tube into the existing tapped hole in the intake manifold.
Reeseb (05-09-2017)
Thank you!
Your breather tube looks like it may be from a C1 not C2. Also long bolt thru neck at engine is missing.
Received 4,583 Likes
C1 of Year Finalist (appearance mods) 2019
And don't forget the gasket that goes on the breather tube first against the block.
Received 1,843 Likes
