[C2] 1967 Coupe rear lower window channel
Frankie, Getting back to this . I just received the new "64-67 Coupe Door Glass rear and upper channels" with the lower felt liner attached. Aren't the lower felts inserted into the channels in my earlier photos? That is what it APPEARS I should be doing or am I messed up again? Thanks.
I'm going to let some others respond Mike Coletta or perhaps Nowhere Man.
Apparently, I can't base my comments of the different approaches used on the later midyears off of my limited 1963 coupe's methods...
What you have is correct. You need to install those into the "steel" channel that you have. there are a couple of "push in retainers" that will line up with the holes in the rear lower channel.(I see them in your picture). No glue is used. Most of the time you have to play with those "ball like retainers" to get them to snap in, and hold. I usually install them into the back channel first, and then slide the whole assembly up through the window slot, and install the top. Not a pleasant job.
Mike Coletta
Mike Coletta
TWINRAY (05-22-2017)
Mike Coletta
Mike Coletta
TWINRAY could you report your experience installing these after you finish? Just removed my glass and tracks this afternoon and will be doing this in the future.
Who did you order your tracks from?
Oh and I put a dab of grease where the push pin went into each hole.
Ordered from Zip but with a Corvette Central label underneath. They are fairly delicate on the spot the channel ends and turns to just felt. Foe some reason the screw hole where it is screwed into the bottom of the channel was off 1/4" on one side (the other side lined up) so I had to drill into the felt and make another hole. The push pins are predetermined where they do into the 2 holes in the channel and into the coupe door. I squeezed all the push pins in a bit with a pliers, I didn't want trouble getting them in. I attached the felt to the metal liner and dropped it into the door. Knowing where the push pins were, I had a 5/16" small square of plywood, centered over the push pins in the felt channel and gave it an easy smack with a hammer. I'd say it would be very difficult to push them in by hand, I couldn't.
TWINRAY
There might be some useful info in the attached PDF. This was one of the first "big" jobs we tackled with our 65. A true "learning experience". One thing you might find useful is to grind out the top of the lower rear window channel so that once you have the upper channel in place (bubble clips installed in door channel), you can tuck the lower channel in behind the fuzzy part and slide it up over that lower "bubble" clip. See page 12.
Hope this helps.
Dave Z
TWINRAY (06-07-2017)
TWINRAY
Hope this helps.
Dave Z
Hope this helps.
Dave Z
