Slow turn / clunking in rear end '65
Received 4,551 Likes
2016 C2 of Year
2015 C3 of Year Finalist
Try changing the rear diff fluid. 80/90 weight gear oil and one 4 ounce bottle of GM posi lube. Sounds like the clutches sticking in the rear diff.
Sullyvette (05-15-2017)
Depending on when you last changed differential fluid, you might be able to get a way with just adding one 4 ounce bottle of GM posi lube.
I had very same issue. I took a bit of fluid out and added Posi Lube. Fixed her right up....Good Luck !!!
RK
RK
Moderator
I used two bottles of posi fluid and drove in opposing circles (figure 8's) for a bit. Worked great.....
Yes, you will DEFINITELY need to either raise the rear end or, better yet, find someone who has lift as there's no drain plug (fluid has to be siphoned) and the access plug is a bit hard to, well access.....
Gary
Sullyvette (05-16-2017)
Figure 8
Before you go to the trouble of removing fluid and adding posi lube take the car to a parking lot where you can run tight figure 8s in both directions . Do it 4 or five times in both directions . Bill
1965 4spd. vert. OK, I had the rear end fluid changed by the dealer. $ 126. not too bad. Mechanic stated that the fluid was pretty dirty. Thought that would cure the rear end clunk. Nope! Did the suggested figure 8's in an empty lot.
At low speeds and turning, I hear and feel a clung from the rear when taking a slow turn. What's up with that? Any suggestions? Thx, as always. Chuck
2016 C2 of Year
Did the dealer put the 4 oz bottle of GM posi lube in? If so, you could try a 2nd bottle. If that doesn't do it you may need Gary Ramedei for a rear diff rebuild.
Sullyvette (05-24-2017)
That still sounds like the problem. They should know better but they don't know much about these old cars. You still need to put in the posi additive - that's what makes the clutches in the posi work smoothly.
Cruise-In III Veteran
I'll 2nd, 3rd, 4th & 5th what all these guys are suggesting to do. It does sound like the dealer replaced the 80/90 gear lube and didn't add the posi additive.This is the GM posi additive you need to add: GM 88900330. Comes in 4 oz bottles. You can buy it here:
Jim
In God We Trust!
Jim
In God We Trust!
Gary
Sullyvette (06-10-2017)
Received 1,974 Likes
It appears the GM product is okay and does contain the limited slip additive. I prefer using a generic API-certified SAE 80W-90 GL-5 gear oil, and you can buy the limited slip friction modifier additive at NAPA for about 8 bucks per 4-oz. bottle. This additive is a generic product that is used in all manufacturers' clutch-type limit slip differentials.
You may have other problems. As miles accumulate the Positraction clutches wear, which increases differential gear backlash. This can be determined externally by checking side yoke end play. With the car on a frame lift push the wheel in and out with someone placing a finger on the side yoke to estimate play. A new axle should have no more than about five thou end play.
As this backlash increases you typically hear occasional "clunks" from the axle, especially on tight turns. At some point the backlash grows to a point where the clunking becomes increasing noticeable and yoke end play increases. The increasing differential gear backlash combined with hard use increases internal shock loading and can eventually cause a differential side gear or pinion to fail.
At this point it sounds like the your axle doesn't have excessive internal clutch wear, but you should try to get a measure of axle yoke end play. Once it gets to .030" you should consider overhauling the axle including a new Eaton loaded Positraction case.
Later models in the C3 era can also suffer from axle yoke end wear due to inadequately hardened yokes, which increases diff. gear backlash, but this type of wear is much less common in the C2 era.
Duke
Duke
Sullyvette (05-25-2017)
I have noticed it occurs when making a right hand turn. I'll check the play measurement. Can this wait till fall? Or, is this something that should be attended to asap? Approx. cost of axel overhaul? Easton Posi case? Dealer or competent garage? Thank you. Chuck
clunk
On a similar note I put a fresh rebuild on a 69 mopar posi unit re-installed back in car, used royal purple 75-80 with the posi additive, so no additional additive needed.Well when I went to try it out a little noise was heard at first drove several miles returned home backed into the garage I thought the rear-end was going to brake there was so much loading on the clutches as i turned 90 degrees into the garage. I was PO. Next day as I took the car back out of the garage same thing the rear was going to brake. Drained off 8 oz of dope added Chrysler post additive topped of fluid went for a ride slowly leaving garage. When I returned home, backed into garage 90 degree turn not a peep quiet as a mouse. Contacted royal purple about this was told the additive was for new style clutching not stuff from the 60s ??? 3 years later still quiet.... I will never use a dope with additive already added. Ric
