RS600/T45 question
RS600/T45 question
Any chance someone here knows the specification for cluster shaft end play? I finally got around to tearing into my RS600 to see if I could uncover the reason it occasionally slides out of fifth and I found that the cluster shaft was never shimmed and it has nearly 0.030" of end play. That translates to that much less disengagement between the synchronizer sleeve and the clutch teeth on fifth gear. As it is, there's only 0.050" now...not enough obviously.
PS FWIW, the main shaft has a end play of 0.0035", probably a reasonable target value for the cluster shaft.
I think I've found the answer but there's still a little confusion. I did a little searching on Mustang forums and found a reference to a spec sheet that indicates zero to 3 thousandths of end play, I also read in a few threads where it was referred to as a preload of up to 3 thousandths. Could that be right?
St. Jude Donor '07
Bill
But the main shaft is not preloaded so I'm guessing neither will be the cluster shaft. SST is also looking for the answer for me.
St. Jude Donor '07
I don't see a problem with that. If you have 0.010 end play with no shims and want 0.003 preload, put shims totaling 0.013 under the bearing race.
Bill
The front bearing. Both the main shaft and the cluster shaft have tapered rollers front and back and there's a shim under the race of the main shaft in the front cover. That limits its end play to around 3 thousandths. No shim under the race of the cluster shaft with about 30 thousandths end play and a fair amount of corresponding side to side play.
Cluster shaft 0.0 - .003
https://www.google.com/#q=t45+cluster+shaft+end+play
click on 3rd entry, download .pdf: Ford T45 Service Manual
Call Stan at Pro-Force Performance if you want to verify. He's a T45 specialist.
Bill
St. Jude Donor '07
Bill
Input shaft .0009 - .002
Too bad about the original assembly problem. You never got to enjoy it, but I think you will enjoy it when you get it finished. It's a really quick shifting gearbox. I just loooooooove mine..................except bolting/unbolting from bellhousing.
Good luck.
There used to be a rebuilder known as "The T45 Source" in Ohio. I understand that Stan (Pro-Force) bought them out last year. The T 45 Source was the go-to guy that the Mustang crowd depended on. I used him once myself. Really great guy. I wonder why he sold the business. Anyway, Pro-Force is another specialist with Borg Warner T45, T54, etc. He might have shims and advice for you.
Good luck.
Good luck.
