Fuel tank sender
Fuel tank sender
So I'm working on a retractable radio antenna and I stopped to look at the fuel tank sender.
I messed with this a while ago. Gage moves left and right so I assumed I need to use up the gas and pull the sender out and replace. Well yesterday while under there I noticed there are no screws holding the sender to the tank. Almost looks like it is a twist to fit. Could that be????????
Received 6,929 Likes
2015 C2 of Year Finalist
Yes it's a lock ring. All GM cars used them well into the 80's
Jack
A little lubricant on the rubber O ring helps as well.
Gary
Part numbers to follow shortly:
Rubber seal is GM #3825206
Metal cam/retainer is GM #3774937
Ebay is good place to buy both...............don't use a non-GM retaining ring. GM or the OER reproduction rubber seal are both good to use.
Larry
vmaxpwc (05-23-2017)
Don't throw away that old sending unit!
Often they can be repaired and I've had mixed results with the Chinesium repros...
You may find you have to re-use the original after fixing it.
FWIW.
Larry
