Any experience with EPAS elec power steering mod?
Received 3,443 Likes
Not brand specific, but had the electric rack and pinion fail in one of our fleet vehicle's a few years back at about 31,000 miles. Cost $3400 to replace it. Not an option I would consider, personally. YMMV........
There are several youtube videos on it but that's not personal experience of course....it's nice feature is that its variable...more assist in tight spots and less with straight-ahead road driving...
I don't know anything about the aftermarket version but my E350 Benz has it. I'm don't know how much computer input it has but it is the best driving car I've ever driven. I wish I could move a lot of features over to the Vette.
The only down side was the installation. I spent 18 hours modifying my steering column and installing it. If EPAS performance offers a steering column that is already modified(which they do for the mustang), definitely buy it!
i just installed an EPAS performance conversion on my 67 mustang fastback. The steering feel is phenomenal! Far better than I anticipated and you can adjust it to your own particular preference. However, I used it with a manual rack and pinion, not a worm gear box.
This is what I consider to be the downfall of such a system on a C1, in that your existing steering must be in top notch condition,and then you must have it modified. Steering box, including column are removed, and then cut down to attach the EPAS in between the lower and upper sections of your column. And then reinstalled, and plus adding the EPAS portion under the dash.
Only if your steering is in top condition, will it work to your satisfaction with the added power steering assist.
If your steering system needs to be renovated to begin with (especially the steering box), any one of the R&P systems would be a better choice.
Plasticman
They most likely offer the C1 and C2 systems with an IDIDIT column. A tilt IDIDIT column for my mustang cost $600. EPAS performance offered their modified unit that IDIDIT makes for around $450.00. If I had not already had the column for several years, I would have purchased the one they offer.
They are now starting to offer a full rack with the EPAS integrated into it for some applications. The owner Jeff is very nice, so it's worth at least a phone call to discuss. Good luck.
Plasticman
I attempted to install one in a different vehicle, (56 Truck) It takes up a lot of room and I couldn't get it to fit. But I see that Epas sells a direct fit for a 53-62, even appears to come with the steering box. At $1450.... that would be a tough call for me.
