C1 Engine/Tranny Install
Good job!
It can be stressful. I would wonder "what if the chain breaks right over the nose?", and stuff like that...
Doug
Doug
AZDoug, wmf62,
I can't agree more with both comments! I almost didn't take the picture with the motor "dangling" over the nose because of the same fear.....
Thankfully, all went well. I also got the new windshield put together and installed yesterday (after cracking the first two). Expensive lesson, but it's done.
Thanks again for all the advice!
Jim
Jim
St. Jude Donor '07
AZDoug, wmf62,
Jim
Jim
Bill
Yeah. What you said.
I did the math with yield strength of even cheap grade 3 steel and cross section of those carb studs, and the math says it is fine by a large margin, but my gut went, no, no, no.
Doug
Doug
St. Jude Donor '07
I would much rather use larger diameter intake or exhaust or accessory bolts to be safe rather than sorry...
Bill
