[C1] Nose emblem speed nuts
Old 05-27-2017, 12:07 PM
kenmo
kenmo's Avatar
Default Nose emblem speed nuts
Two of the three metal pins on my trim ring broke off, so I purchased a new nose emblem kit from Corvette Central. It includes a new gold nose emblem, new trim ring, rubber gasket, backing dish and three speed nuts.
Anyone know what tool is used to put these speed nuts onto the trim ring. Previously I used the hex type speed nuts and socket. A socket appears like it will not work with the new speed nuts...
These are the original type which GM used in 1960. The hex speed nuts will not fit the pin of the new trim ring as the pins are quite a bit thicker. The older one was quite worn.
Cheers & many thanks...
Ken
Old 05-27-2017, 12:24 PM
Frankie the Fink
Frankie the Fink's Avatar
Received 7,082 Likes on 4,736 Posts
Army
My 61 trunk emblem came with those...I just twisted 'em on with my fingers....
kenmo (05-27-2017)
Old 05-27-2017, 12:39 PM
wmf62
wmf62's Avatar
St. Jude Donor '07
thread the studs and use regular nuts
Bill
Old 05-27-2017, 03:43 PM
firstgear
Support Corvetteforum!
firstgear's Avatar
2019 Corvette of the Year Winner
St. Jude Donor '15
I threaded mine as well......I used the other speed nut that they have.....saved me some cuss words....
Old 05-27-2017, 04:02 PM
TCracingCA
TCracingCA's Avatar
Received 1,683 Likes on 1,005 Posts
I must be neurotic because I take a hobby die set and thread the posts carefully and use like nylon little nuts!
Old 05-27-2017, 04:07 PM
Harold Davis
Harold Davis's Avatar
If you look on line at the Corvette Central parts there is a spot that says More.
Hit that mark and it shows you extra tools and parts to complete the job
the part you need is 341001. Tool to install nuts.
Harold
Old 05-27-2017, 10:46 PM
kenmo
kenmo's Avatar
Thanks kindly for all the replies....Much appreciated...
Old 05-28-2017, 12:53 PM
SWCDuke
SWCDuke's Avatar
Received 1,974 Likes on 1,188 Posts
Those in the photos are not what GM originally used. The original speed nuts were stamped hat section with a 5/16" 3/8" hex. The plant also packed some dum-dum into the hat section as a water seal. Look at the AIM.
They self threaded onto the stud. I can't imagine they are not available today, as they were widely used across all GM product lines.
Duke
Old 05-29-2017, 10:14 AM
waynec
waynec's Avatar
Duke
Yep, they are available as a kit from Corvette parts suppliers and look like this:
speed nut
Old 05-29-2017, 10:25 AM
kenba
kenba's Avatar
Location: PHOENIX AZ. WHAT A MAN WON"T SPEND TO GIVE HIS ASS A RIDE
speed nut
You are correct. This is what they look like from the factory.
Old 05-29-2017, 01:45 PM
kenmo
kenmo's Avatar
I have some of those in my garage. I find them much easier to install. And did use the few I found on Sunday when I put replaced the emblem.
To Nose emblem speed nuts
Quick Reply: [C1] Nose emblem speed nuts
