What tools do I need to take a differential plug out of a 65
http://www.zip-corvette.com/63-67-c2...fill-plug.html
Just match a wrench up to the plug. From what I remember it's about 11/16''...not sure. I filled mine with the housing on the bench, you may need a hose and funnel to get the additive in
Received 6,943 Likes
2015 C2 of Year Finalist
Sears use to sell square sockets for such plugs as this. I think it is 3/4. The real tool trucks carry them.
Sullyvette (05-29-2017)
A crescent wrench sometimes works; the Sears 8 pt sockets are best, they'll work on the square plug. If you round off that plug with a crescent wrench - then the real fun begins...
Amsoil makes a nice plastic hand pump to fill up differentials and transmissions that fits their bottles. Much neater and precise vs spilling fluid everywhere...
https://www.amsoil.com/shop/by-produ...tle-hand-pump/
Probably the best answer.
I purchased a complete set of 8 pt sockets just for this job, only to find that the plug would not fit any of the sockets. Too much casting flash or just too rough finished dimensions. Used a crescent wrench and all is good.
A 12 pt standard socket may fit...........you can try. Not certain of the exact size needed, but will be less than 1 inch.
FWIW.
Larry
FWIW.
Larry
Also works for 4-speed trans.............just may need a bit longer tubing length and then pour from the engine compartment. Quick and easy.
Both the rear axle and the trans fluid can be syphoned out the housings/case using the same tubing. Best to do this in the warmer months or use a suction gun if the fluid is thick.
Larry
8 pt socket has worked fine on both of my cars as recommended by Tom Parsons IIRC. Also works on the transmission drain plug.
Did the funnel in the engine compartment thing too. I have the stains on the garage floor to prove it. That's when I spent my life savings for the plastic hand pump.
Larry
The following 2 users liked this post by Powershift:
Sullyvette (05-29-2017),
tuxnharley (05-28-2017)
Used the Harbor Freight suction pump to put the lube in which worked better than I thought it would. Put (shot) the anti slip additive in with a medical syringe and didn't spill a drop.
I've been using a OLD Model A or T wrench you can find at most swap meets. Fits perfect, no slip and strong.
2023 C2 of the Year Winner - Unmodified
2020 C8 of the Year Winner - Unmodified
2020 C6 of the Year Winner - Unmodified
2020 C2 of the Year Finalist - Unmodified
2017 C2 of the Year Finalist
2016 C2 of the Year Finalist
I just pay this guy a few bucks! Has all the right wrench!!
Received 1,919 Likes
May I suggest a set of hemostars?
j/k
j/k
Ok, I read your comments and suggestions.
After hand fitting a few 1/2 in sockets, I found an 18MM socket fit best. With a six inch drive the removal was simple. I was reading post # 12 as I was approaching a Pep Boys. Six bucks, what a great idea (Gizmo). I held the bottle higher than the diff. and then opened the spout, easy peezy. The only spill was some additive from my shoulder tipping over my second bottle. DUH
I hand tightened the filler bolt, and then used the 1/2 drive to tighten the bolt. It seems that the bolt is slightly raised from the diff. and the filler tag, seems loose. Not cross threaded. I muscled the bolt pretty good, didn't want to snap it. any thoughts? Not leaking. Thanks again. Next time, I would do this job myself. No dealer involved. Unable to do my figure 8's today, downpour in upstate NY.
