'67 Restomod completed
Old 06-03-2017, 01:28 PM
USMC 0802
Support Corvetteforum!
USMC 0802's Avatar
USMC
Wow, amazing work and I love the workshop!
Well done.
Old 06-03-2017, 05:21 PM
NightshiftHD
NightshiftHD's Avatar
Ya Ken, you gotta show us the details on the backup camera ... my 66 is still apart and I want to add that to mine. I think it's a much better solution for us old farts than putting a RH mirror on the door ... as long as the camera can be made hard to see from the back. I like Frankie's solution on his 63 which uses an blue tooth app on his phone rather than a fixed LCD.
Old 06-03-2017, 05:38 PM
mike coletta
mike coletta's Avatar
Received 1,067 Likes on 513 Posts
Bruce, Ken, Just for future reference. When working with foam, you can use epoxy resin vs. polyester. Epoxy will not attack the foam. It is a little thicker, and harder to get it to penetrate the mat, but you can thin it with a little rubbing alcohol, which will not attack the foam either. I use West Systems epoxy. Most of the big box boat suppliers carry it. You can buy it in a pint (part a and b), or a 55 gallon drum. It mixes 50/50, and takes about 6 hours to set.
Brucebodyman (06-04-2017)
Old 06-03-2017, 08:50 PM
Scott Marzahl
Scott Marzahl's Avatar
Looks awesome Ken! Love the little details in the build and I bet that 525 really scoots. I'm currently sorting out the details for a backup camera installation using a Pioneer 5800 stereo display, numerous camera options on the market some built into a licence plate frame.
Old 06-04-2017, 08:48 AM
3JsVette
3JsVette's Avatar
Received 2,489 Likes on 1,644 Posts
A really gorgeous '67 restomod. Outstanding attention to detail and extremely tasteful. Well done!
Is this a local New Jersey owner? If so I hope to get to see it in person.
Old 06-04-2017, 09:13 AM
65tripleblack
65tripleblack's Avatar
Simply awesome!!!!!
You have an incredible imagination, and your artistry is always beautiful.
Old 06-04-2017, 11:49 AM
MarkC
MarkC's Avatar
C2 of Year Finalist (performance mods) 2019
Nice!
Old 06-04-2017, 12:56 PM
Beggers
Beggers's Avatar
Wow Ken, that is another nice build, very fast as well!
I loved the sound of those Allen's pipes on my 63 with that 525 horse, that car rocks great job! Brian
Old 06-04-2017, 01:19 PM
OldKarz
OldKarz's Avatar
Location: On the bank of the Columbia River..... Washington State
Nice build Ken! Looks great!
Old 06-04-2017, 09:05 PM
Ken Sungela
Ken Sungela's Avatar
Thanks Mike,
I used the west system stuff but noticed it didn't wet the mat as well as the fiberglast stuff like you say, and it takes longer to harder. I got by with the polyester this time.
Old 06-04-2017, 09:19 PM
ILBMF
ILBMF's Avatar
Looks great! I'd love to own that
Old 06-04-2017, 09:56 PM
Ken Sungela
OK, here are the details on the backup camera. I used a Boyo VTM500S monitor and the VTL275HD license plate camera. The actuator was from Actuonix, L16 Linear Actuator, 50mm, 35:1. The time delay relay was Siemens 7PV1540-1AW30.
The bottom end of the actuator mounts to a point just forward of the cross bar in the dash, so I made a flat bracket that bolts to the under side of the cross bar and extends forward about 1/2". Its adjustable so you can get the proper travel and still have the speaker grill drop down flat on the dash frame. I thought about integrating an electromagnet to hold the speaker grill down, but its heavy enough to stay seated and therefore don't need it.
Any questions, let me know.
The following 2 users liked this post by Ken Sungela:
firstgear (03-29-2018), Kerrmudgeon (12-10-2017)
Old 06-05-2017, 03:40 AM
  #33
NightshiftHD
Awesome Ken. Can you show where you mounted the camera? Bill
Old 06-05-2017, 06:07 PM
  #34
firstgear
firstgear's Avatar
2019 Corvette of the Year Winner
St. Jude Donor '15
Thanks guys. It was a long road but happy with the final result. The owner loves it. We did a test drive on Tuesday. I thought it may be too much car for him, but he proved me wrong.
Just the actuator holding the hood down. There are some rubber bumpers on the hood to make it level with the fender. I need to add one more bumper on either side to limit the side ways movement when closed.
The door panels were a LOT of work. I thought the foam was great until the resin started melting it. Fortunately the resin kicked in time to still hold the shape. I added more activator on the second panel for a faster kick. Still had to smooth it out with body filler. I'm going to try Sintra (PVC foam board) or equivalent next time.
Yes, air filter in the chrome pipes.
Mike C. - I'll post a video of the backup camera popping out of the dash. Pretty slick and simple design which only took about 20 hrs. ... you know how it goes.
I used my hood actuator to hold the hood down as well on my '60 Vette.......been that way for 10 years. I took my actuator apart and turned down the push/pull rod to make up for the chrome growth. Also chromed the housing....was no big deal. Nice job on the build.
Old 06-06-2017, 08:57 AM
  #35
Ken Sungela
Hi Bill,
Post 32 shows the actuator from underneath the dash. You can see a bolt to the right of the actuator and there is another you can't see. I just used a 2" hinge and some heavy duty two sided tape to attach it to the monitor case, then bolted it to the dash frame. I wedged out the fiberglass frame a little just to move the assembly forward 1/8-3/16" or so. If you are recovering your dash with leather, I would cut out the strip of fiberglass that goes over the speaker and cover right over the whole opening. Then just cut a small rectangle for the actuator to go through.
Old 06-06-2017, 11:01 AM
  #36
Big Hit
Big Hit's Avatar
2017 C2 of Year Finalist
Nice Ride...Nothing better when done correctly!!!
Old 06-08-2017, 07:13 PM
  #37
DomL64
DomL64's Avatar
It came out beautiful ! Now I have something to look at as I redo mine.
Thank you for the great postings !
To '67 Restomod completed
Old 06-11-2017, 10:49 AM
  #38
NightshiftHD
Hi Bill,
Ya thanks Ken. I understand your monitor mounting ... I was asking about the camera. But I looked up which camera you used and can see its a license plate frame one. Love the whole setup. Nicely done. Cheers, Bill
Old 06-11-2017, 11:31 AM
  #39
Tom Austin
Tom Austin's Avatar
Received 1,962 Likes on 664 Posts
https://youtu.be/pwm1rj3Atyc
Love this idea Ken . . . what would it take to make that screen more functional? . . . to include GPS NAV/multimedia/Bluetooth capable? Would love to have all of that in a pop-up screen!
Tom
Old 06-11-2017, 12:08 PM
  #40
Jeff Garner
Jeff Garner's Avatar
AWESOME build! Enjoyed all the pictures.
Quick Reply: '67 Restomod completed
