Radio issues
Radio issues
Yes I do love to listen to my C2 roar though the town but thought it would be nice to also listen to some tunes. Currently barely get 1 station to come in and its 95% static 90% of time. What should I be looking at to get more stations to come in? Factory radio and atenna 67 C2. Thanks in advance guys !
I've got a cheap rubber antenna I bought at Oreilly's for around 9 bucks that I use to plug into radios to eliminate the antenna and antenna wiring as possibilities. You can plug in an antenna without removing the radio.
Could be bad inside radio, but gotta start somewhere. I have had original C2 radios act up and not get good signal when the am/fm slide hadn't been moved in a while and if I slid it back and forth rapidly a few times to clean the dust off, they worked better.
This one is $21 bucks, but they have cheaper ones in the store to use for test purposes. Or if you have one from another car as long as it uses the same plug type as yours.
http://www.oreillyauto.com/site/c/de...0201&ppt=C0325
radio
Thanks Frankie. I suspect the atenna as well. Is there an easy way to check the connection into the radio with having to remove the radio itself? Do you have an diagrams or pictures of what I should be looking for at the actual atenna (ground)? Thanks again!
If you'll try what I told you and connect an external antenna into your radio antenna plug you could eliminate all that without changing or removing anything. If it still won't pick up any stations you'll know it's in the radio
If you remove the PS center console side cover you can make sure the antenna is secure and make sure all the mounting hardware is there for the radio...
Make sure your power and speaker connectors are solid and shine a light up there and examine the speaker cone. Those can turn into newspaper over the years.
Try what 65GGvert suggested. I had the same problem after a full restoration. Rebuilt radio, new speaker, new antenna and cable and new hardware -- but couldn't tune in a station a half mile away. I plugged in a cheepo antenna from Autozone and had great reception. The original new antenna cable was defective right out of the box. I replaced the bad cable (PITA) and that fixed the problem.
Received 1,533 Likes
Do all of the above:
Check the speaker for deterioration, cracks, etc. Check the radio and antenna connections for corrosion. Check the ground to both the radio and antenna. Try a temporary antenna. Make sure the ground plane is in place at the antenna. This can all be done without removing the radio, but you may have to stand on your head to see things under the dash.
Bnowill10 (06-23-2017)
Radio/CD player
Disclaimer...never used them, just remember seeing it when looking at one time.
