1965 coupe TI changeover
Has anyone changed from TI ignition to a new distributor with pertronix module? I have 65 coupe that has factory TI, I have the upgraded module but just don't trust it. I've had the car for 4 years and put a lot into it. Before getting the distributor rebuilt I was considering getting a new unit with pertronix. They're readily available and reasonably priced. Is it as easy as changing the distributor and wiring in the module? Ballast required?
Melting Slicks<br><img src="/forums/images/ranks/3k-4k.gif" border="0">
Received 1,946 Likes
You can make this change without getting a new distributor. Remove the TI module, the TI related parts in the distributor, add the Pertronix to the distributor and add a ballast resistor and you are all set.
Received 6,943 Likes
2015 C2 of Year Finalist
After reading on here that widget is no more reliable then TI.
Received 2,130 Likes
2015 C2 of the Year Finalist
Dan
To changeover
I have the upgraded module, even have a spare. Can't find any history on the car so I'm starting from scratch. Bubba did a number on the car, I've cleaned most electrical issues up and have started getting other things straight. The distributor could use a rebuild, never did one, so i was going to take the cheap way out and replace it. It has factory aluminum high rise but in bad shape so I found a nice original one and will replace it. Distributor has to come out so thought I would go with a new standard one.
C2 of Year Finalist (stock) 2019
also how can a intake that is on a car and runs be in bad shape that you need to replace? there is no moving parts to a intake. as long as its not cracked and leaking there is only cosmetics things.
sounds like you got money burning a hole in your pocket and you opened up a new summit book and want to go shopping. or you want something out of your car that it can't give it
The intake has a cracked mount so I bought a new one. I have no idea who has done what to the car, I've had it 4 years and have done quite a bit, both myself and by shops. I'm not afraid of anything I've done and it isn't about having extra money. It's about making it a reliable driver. I got a quote to rebuild the TI distributor, $1000. No thanks. I don't know anything about them and can't find anyone local who does so I would rather not learn by trial and error. I can get a nice rebuilt tach drive with pertronix for less than half the cost to rebuild this one. I've talked to guys who have experienced a TI that just quits. I want to drive this car on a regular basis, the ignition system is the last thing I need to update. I've done everything from a new gas tank, old one was seeping, to new rear trailing arms, complete brake update, new fuel line, frame repaired, all new front end, you name it. This winter I'll rebuild the clock, get the radio working and put new carpeting in it. Even going to get the cigarette lighter working.
If You'd like to follow the above suggestions I see no reason not to.. They are sound ideas.
If you want to go further and change out the ignition system then a Nice MSD Pro Billet Ball Bearing Tach drive distributor is a nice way to go. Also adding the new MSD 6Al Digital Sparky Box. This will insure accurate timing and a Nice slightly longer duration spark during crankshaft rotation.
How ever..their is a Cost associated with this mod. Your ignition System is a Good one but the new tech will improve reliability.
Others here have their own opinion pro and con when it comes to this MSD Upgrade and should be respected as we have many experts here with solid factual opinions.
It all depend on how you feel about taking a Good 50 Year old plus design and changing it when others find their TI reliable.
Sit back and enjoy the comments and suggestions and decide for your self. Our Members will lead you in the right direction.
you can rebuild a TI distributor cheaper then 1000 bucks. there is no need to replace the magnet and pick up unless your car doesn't run now. I have more faith in TI or points then I do pertronix but that is just me.
Corvette Central sells their rebuilt BB TI Dist. for just over $900.00.
I like the advice Viet Nam Vett gave you as well as some of the others.
A good running TI even if you think bubba did it is still worth it because it's functional as mentioned and you don't have to spend any more out of pocket money.
Plus on the forum in the search engine you can find a ton of articles on how to troubleshoot and rebuild your TI dist. If already as you say you've worked out many of the problem details with your ride I would stay with TI. It is a fairly simple system to learn. Parts are easy to replace. Go here if you haven't already - http://www.tispecialty.com.
Having said that - for the extra cost to go all MSD may be worth it for you as Viet Nam Vett opined.
To take your TI and turn it into a 'pertronics' or whatever other similar system is a step down from what you already have I believe. Get on the Search function - if you can't find your answers there - just bring them back here.
Good Luck
65-StingRay
Wayne
Good Luck
65-StingRay
Wayne
Good Luck
65-StingRay
Wayne
Good Luck
65-StingRay
Wayne
https://www.msdperformance.com/produ...let/parts/8572
A little research can yield you a Lower price.
Also Here is the New MSD Digital 6AL Spaky box that works with the MSD Distributor...It now has a Quick disconnect at the box. Again Search for the best price..The one I belive shon is without the built in limiter... (6A) The L on the end would have an adjustable limiter built in.... (Mo Money)
https://www.msdperformance.com/produ...eet/parts/6201
With Adjustable limiter....
https://www.msdperformance.com/produ...eet/parts/6425
