Hydraulic Clutch recommendations for C2
SLWRNU (06-28-2017)
Interesting. I did a search and found that there are various opinions on this. However, I am using an SRIII frame and while it have provision for the manual clutch, I am still going to use a Hydraulic Clutch. I can reinforce the firewall or use the Bowler version (of Hydraulic Master)...it doesn't use the firewall (uses the original clutch rod mount)..Bowler solution: https://www.bowlertransmissions.com/...let-reservoir/
St. Jude Donor '07
OK, the non-stock frame changes things...
personally, I don't like the idea of the slave cylinder being inside the bellhousing; IF there is a system with an external slave, then OK
Bill
Bill
Received 3,043 Likes
St. Jude Donor '05
had a hyd slave for yrs a manual will last forver, the hyd wont esp if the car sits a lot. Like anything its a trade off, light pedal vs-
if you like to powershift keep the manual.
I've had bad luck with aftermarket hydraulic throwout bearings. 2 McLeod setups at over $500 each and 2 Ram setups. None of the 4 lasted more than 1 or 2 thousand miles. They typically may start to drip, then pop all at once leaving the pedal on the floor. This was on a Mustang. The best hydraulic throwout bearings are OEM style that use an accordion style boot to protect the seals from clutch dust. Other than that, I would also suggest an external slave just from my own experience.
With that said, it appears that Zip sells the accordion style kit. However, you will need to change out the front bearing retainer on the tremec TKO. Not a big deal, but if you go with this kit, make sure to seal the bearing retainer with anaerobic sealer. I made the mistake of using RTV on my first hydraulic conversion and had to pull the transmission back out due to fluid leaking from the retainer. RTV and transmission fluid do not get along well at all.
http://www.zip-corvette.com/55-82-hy...nsmission.html
SLWRNU (06-28-2017)
I prefer the external slave to the internal throw out bearing type. They do leak and it's much easier to deal with that rather than removing the trans, JMO. I have a T56 6sp in mine out of a 1996 Camaro with the original slave cylinder. I installed a master cylinder from a 1985 Chevy pick up and hooked it all up together with a hose and connectors from Speedway. I had to glass in a metal support in the floor but it was inexpensive and I've had no issues for 4 years now. But if I do the parts are readily available from any parts store and easy to change. The trans already had the slave on it so the whole thing cost me about $100.
Really good info. Most of the kits are much more expensive than that, even though the whole deal is really pretty simple.
It's also tricky to bleed. You can't bleed it like a brake system. If you have questions you can PM me.
Received 3,048 Likes
C1 of Year Finalist (performance mods) 2019
I have never liked the mussy feeling of a hydraulic clutch plus you can not power shift one.
Bill, I'm not trying to argue, but how many have you used? For a stock car I think mechanical linkage is fine, but not for a full blown restomod. When properly set up, they will not have issues with reacting late or have a mushy feel as someone else mentioned. I'm not sure what the on and on is, but I doubt the list is long as it can only go so far. As far as leaks are concerned, well, I suppose that depends on the manufacturer.
St. Jude Donor '07
the ONLY personal problem experience I have had with a hydraulic clutch is with a MGA. the slave cylinder piston pushed out, hence no clutch..
only other use was a 93 ranger pickup, but I was appalled that you had to pull the transmission if you had problems...
I agree, if one doesn't have a problem, then there is no problem.. but, given the choice, I will never use one
Bill
