Checking "V" belt tension
Old 06-27-2017, 07:55 PM
Mr Fufu
Mr Fufu's Avatar
Default Checking "V" belt tension
How tight should the alternator, A/C compressor, and power steering pump belts be tightened?
On a recent long drive I noticed a burning rubber smell coming into the cabin. Upon examination of the engine compartment I discovered that the power steering pump had come loose, causing the reservoir to rub on the alternator belt from time to time. The belt itself was intact, but frayed along about 30% of its length where it rubbed against the pump reservoir housing.
So, yesterday I replaced the frayed belt with a new one. In order to replace this belt I had to first remove the A/C compressor belt and the power steering belt. These belts were in good condition, so I re-used them. I also snugged up the power steering pump so that the reservoir would not interfere with the alternator belt.
I tightened all the belts and everything seems fine. But, how tight should each belt be? How critical is the tightness of each belt? I know if they aren't tight enough the belt might squeal, or become glazed from insufficient tension, but beyond that, how tight is too tight?
The 1967 Chassis Manual states that there are specifications for the tightness of each accessory belt listed "in the Tune-Up Chart section". But, I can't find any Tune-Up charts in this manual! Maybe my copy is missing some pages?
I bought a $20 NAPA "V-Belt Tension Gauge" that's supposed to measure the tension of the belt when placed along its lenght. You press down on the device until a 'click' is heard and then read the tension from the gauge. How well do these gauges work? Are they reasonably accurate? There are dial-indicator type belt tension gauges available, but these are much more expensive.
So, what's the best way to verify belt tension, and where do I find out how much tension to apply to each specific accessory belt?
Your advice is welcomed, as always.
Alex
Old 06-27-2017, 08:12 PM
Frankie the Fink
Frankie the Fink's Avatar
Received 7,082 Likes on 4,736 Posts
Army
For 40 years I have used 1/2" deflection of the belt, with my thumb, along its longest length.
Old 06-27-2017, 08:15 PM
leif.anderson93
leif.anderson93's Avatar
Received 3,090 Likes on 1,859 Posts
Middle of the page. Or, Frankie's way, good rule of thumb...no pun intended (or, maybe there was).
Mr Fufu (06-28-2017)
Old 06-27-2017, 08:50 PM
R66
R66's Avatar
Received 1,530 Likes on 1,032 Posts
Go to the belt manufacturer's web site, Gates, Dayton, etc. there is guidance there.
In the Nuclear industry there is a procedure that tells how to use the gage.
Frankly (no pun intended on Frankie), I use the thumb and 1/2" deflection on my cars. Be aware that after a week or two of use, the belts WILL STRETCH. Retention them and DRIVE IT.
Old 06-28-2017, 11:38 AM
Powershift
Powershift's Avatar
Received 1,681 Likes on 1,307 Posts
Good advice..........
For the alternator and PS, I just pull on it pretty hard by hand......and then tighten the adjusting bolts.
For the A6 AC compressor I use a 18 inch bar to wedge against the engine and compressor to tighten the AC belt. I don't pull on it with all my strength, but I pull on it pretty good. Then tighten.
It is best to have a helper tighten when you are pulling..........but it can be done either way. Your choice.
I have never used a belt tension gage in 50 years on any of my cars, but that doesn't mean it isn't a good idea. Only that it is unnecessary for many of us. PS: I never caused a bearing failure from over tightening a belt and never threw a belt from under tightening it when I was racing.
Larry
Old 06-28-2017, 12:50 PM
Mike67nv
Mike67nv's Avatar
2018 C2 of Year Finalist
2015 C2 of the Year Finalist
The pic below is the type of tension gauge used by GM in the plants back in the '60's. In the early days, the assemblers just used pry bars but then the plants developed different types of torque devices for the operator to use and tension was randomly checked by roving process monitors using a gauge. Belt torque became a fairly big deal before the use of tensioners. There were a fair number of warranty problems caused by over-tensioning - especially alternators.
Old 06-28-2017, 01:26 PM
Mr Fufu
Mr Fufu's Avatar
Thanks for the tips on belt tensioning, guys!
I'll re-check the belts after I drive the car for a week or two just in case they stretch a bit, and I should be good to go.
Enjoy your cars!
Old 06-28-2017, 03:49 PM
Powershift
Powershift's Avatar
That is why I only adjust the alternator belt by hand. It is probably the first to have issues if belt is over tensioned or if a pry bar is used.
Larry
Old 06-28-2017, 04:49 PM
92GTA
92GTA's Avatar
I have always just done the thing where you try to rotate the belt by hand and I make sure it won't twist more than 1/4 of a turn, or 90 degrees.
Mr Fufu (07-21-2017)
To Checking "V" belt tension
Quick Reply: Checking "V" belt tension
