'64 No rear parking lights.
While performing a normal preflight check, I noticed the rear parking lights are out. The rear turn signals and brake lights work and the front parking lights and turn signals are good. Headlights good also. A head scratcher for me. Anyone had this problem ?
Have you checked the bulbs?
I know that for both to go out around the same time is uncommon but, I've seen stranger things happen.
Gary
Gary
dlaw7822 (07-01-2017)
Received 6,943 Likes
2015 C2 of Year Finalist
Did you have the headlight switch pulled to the first detent to the running lights or to the second detent to the headlights with no rear lights
Did you check the fuse marked tail lamps? Tail lamps don't go out when headlamps are on like front parking lights do, they burn in both positions. If you check, you'll probably find your dash lights are out too. When tail light fuse blows you also lose voltage feeding inst lamp fuse.
Second fuse from bottom. Don't just look at it, measure it or replace it, it can be separated inside the glass at end cap
Yep. Tried 1st and 2nd position. Had to in order to see if the front lights worked. Panel lights are also inop, no power to the panel light fuse clip. Suspect the green wire lug on the back side of the fuse block came off when re-attaching the fuse block after fixing a previous issue.
Well 65G, you nailed it. Dash lights ARE out, no power to the fuse clip. Either it's the fuse or the green wire on the back side of the fuse block got disconnected or pinched when re-installing the fuse block ,after fixing a previous issue. Incidentally all this car's wiring is amazing shape but naturally, the end connectors show their age.
Maybe I'm missing something. Since, as you say, they are "on different filaments" why isn't it possible for the brake and turn signal "filament" to work while the parking light "filament" can't be burnt out thus, there will be brake/turn signal but, no parking light?
Gary
Did you mean a different "fuse"?
Gary
Gary
Gary's '66 (07-01-2017)
The green wire off will kill your inst lamps, but not your tail lights. The tailights voltage comes from the same red wire that feeds your brake lights and they work. You've either got a bad fuse, fuse holder, or the BROWN wire on the second fuse up from the bottom may have come off. It could also be in the light switch or wire to it, but if you don't have 12v on both sides of the second fuse, the problem is right there at that spot in the fuse panel. Change the fuse first, then check this wire: That brown wire off will kill both your tail and inst lamps.
