[C2] Issue with Carb upgrade from Carter to Edelbrock 327CI & 300HP
Hey guys I got a question Or problem I purchased this 1964 327 300 horse manual with side exhaust and a Small cam a very original car .
My Carter carb was in need of rebuilt but I opted to box it up and save to have rebuilt at a later date .
I bought a new Edelbrock PN# 1406. 600 elec choke . I went threw the install fine and car started & runs pretty good but I'm getting a popping or cackling when I decelerate which never happened with the Carter.
I'm assuming it's to rich. I set the 2 idle mix set screws per instructions.
Turn clock wise till motor RPMs slow then turn back 1/4 to 1/2 turn on both left and right mix screws.
With the side pipes and window down it's very annoying.
Which brings me to my next question is there anyway to quiet down these factory side pipes? I know LOL give them to you
I'm wondering if this could be in the timing issue ? Not checked what it's set at now will have to find my timing light and see. ANY Suggestions My friends ?
Rebuild the Carter carb and dump the generic Edelbrock. That carb is not optimized for your engine.
Popping back on deceleration when engine vacuum spikes can be due to a vacuum leak or lean mixture.
Look for leak around intake and make sure exhaust manifold bolts are snug.
Make sure you adjust the emulsion screws when the intake plenum is hot plus make sure the transfer slot is exposed when the throttle blades are at idle position. try moving the timing advanced or retard to see which way helps. Take a big swing at it so you get a idea which way to go. The Carter probably gas a richer idle circuit.
Rubc555 (07-10-2017)
When you let off the throttle and decelerate the high vacuum that's created by the closed throttle blades along with the valve overlap from the camshaft can pull exhaust back into the intake manifold. This exhaust can further dilute the mixture causing poor combustion and a lean mixture. When this happens the combustion can be late causing the after burn.
I used the stock adapter in Lou of the one speedway sent so I may take it off and look a little closer we if there is a difference
Received 1,534 Likes
What adapter? should be a bolt on.
Received 1,857 Likes
Thanks for the correction.
Can't tell you how many hours I have spent trying to tune in a Edelbrock aftermarket. Rod, jet, and spring changes to get it right (have a ton of parts left over). Out of the box carbs are generally jetted rich for sea level air, whether it be an Eldebrock, Holley, or etc.
I am not a carb expert, but I have rarely found a 4V carb perform better than the original GM carb other than on racing engines.
2018 C1 of Year Finalist
Thinking the bottom end. I have a couple of adapters (along with a few AFBs) forgot about that.
