C2 Why does the glove box door on my '67 open when I hit bumps? - CorvetteForum - Chevrolet Corvette Forum Discussion
C1 & C2 Corvettes
General C1 Corvette & C2 Corvette Discussion, Technical Info, Performance Upgrades, Project Builds, Restorations
Old 07-12-2017, 10:03 AM   #1
TWINRAY
CF Senior Member
TWINRAY's Avatar
Default Why does the glove box door on my '67 open when I hit bumps?
I mean, everything seems tight and screwed down. And why do the "limit" rods come out of the holes in the frame in the process? Am I missing a part?
TWINRAY is offline   Reply With Quote
Old 07-12-2017, 10:10 AM   #2
Frankie the Fink
CF Senior Member
Support Corvetteforum!
Frankie the Fink's Avatar
Not near my car but IIRC there are rubber grommets that are supposed to catch the rod hooks.... at least on my 63. Sounds like your door latch needs tweaking.
Frankie the Fink is offline   Reply With Quote
Old 07-12-2017, 10:12 AM   #3
hope2
CF Senior Member
simple latch adjustment with spacer. yes, rubber grommets, if in place adjust the arms.
hope2 is offline   Reply With Quote
Old 07-12-2017, 11:09 AM   #4
TWINRAY
CF Senior Member
TWINRAY's Avatar
I looked in one of my supply catalogs and it didn't show much. I live near LI Corvette Supply and will look at their catalog, thanks for the replies.
Old 07-12-2017, 02:12 PM   #5
tuxnharley
CF Senior Member
tuxnharley's Avatar
You can also bend the limit rods slightly downwards at the hook ends so that they engage more securely.
tuxnharley is offline   Reply With Quote
Old 07-12-2017, 05:31 PM   #6
Railroadman
CF Senior Member
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18
Railroadman's Avatar
Bumps? You drive over bumps?
Railroadman is online now   Reply With Quote
Old 07-17-2017, 01:09 PM   #7
zr1bill
Junior Member
Quote:
On my '65 I tried bending the latch a bit and it snapped off. Got a new one and put two washers under latch and it works perfectly. I also put some graphite lock oil into the mechanism and now it's very easy to open and close. The striker slides in and out much easier.
zr1bill is offline   Reply With Quote
Old 07-17-2017, 03:45 PM   #8
jprop
CF Senior Member
jprop's Avatar
Quote:
This is also the way I fixed mine. Put a small spacer under the chrome catch at the top of the inside of the glovebox. It lowered the catch enough to hold tight.
jprop is offline   Reply With Quote
Old 07-17-2017, 05:49 PM   #9
DZVette
CF Senior Member
DZVette's Avatar
Quote:
Yes, there are grommets for the rods and there are also rubber bumpers. On our 65, it takes a little force to push the door into latched position. Once closed, the door is quite snug. You might also try adjusting the fore-aft adjustment of the catch tab.
The fix suggested above, i.e., washers or spacers to drop the catch down as well as tweaking the rods a bit are also good recommendations.
Dave Z
DZVette is offline   Reply With Quote
Old 07-17-2017, 05:55 PM   #10
Brian VH McHale
CF Senior Member
Brian VH McHale's Avatar
LI's and Dr. Rebuilds are must have catalogs for part description and pictures. JMHO
Brian VH McHale is offline   Reply With Quote
Go Back   CorvetteForum - Chevrolet Corvette Forum Discussion >
Reload this Page
  • [C2] Why does the glove box door on my '67 open when I hit bumps?
    Related Topics
    Thread Thread Starter Forum Replies Last Post
    I wonder why . . . juanvaldez Politics, Religion & Controversy 19 05-23-2017 12:12 PM
    Reviving Old Threads Richard Daugird C3 General 6 05-10-2017 07:09 PM
    Why a CAI corvettecolin C6 Corvette General Discussion 29 12-15-2016 01:21 PM
    How many of you dems oppose Kate's Law? bubba68ss Politics, Religion & Controversy 23 07-01-2016 04:33 AM
    Search this Thread:
    Click for Advanced Search
    Posting Rules
    You may not post new threads
    You may not post replies
    You may not post attachments
    You may not edit your posts
    BB code is On
    Smilies are On
    [IMG] code is On
    HTML code is Off
    Trackbacks are Off
    Pingbacks are Off
    Refbacks are Off
    Forum Jump
    Sponsored Ads
    Vendor Directory
    • Ask a Question
    Question Title:
    Description:
