[C2] Where can I buy this disconnect switch
I've had the Gold Battery Brain on my 63 for 10 years now and other than changing the battery in the fob, it's been flawless. No need to open and close the hood or fumble around with a light if it's dark. Push the button, hear the click, and walk away....
https://www.summitracing.com/search/...y-vendors-_-ad
Originally Posted by bluestreak63
I bought a knife one (wirthco?) and can't get it to work on the neg terminal. The knife wants to keep hitting the blower housing connections.
SeeYah (07-18-2017)
St. Jude Donor '07
I quess I've been lucky with mine, whatever they are made out of... BUT, they are 'cheap' enough and readily available to replace if necessary
Bill
I have bad experience with these. When I attempted to solder the cable to it (I had a version that required that rather than clamping) using a simple camping gas torch, the whole thing just melted!
I installed the ones of the picture, they do perfectly well and have top side insulation which helps cause the expansion tank is very close
St. Jude Donor '07
Bill
Basic Hella switch with a removable red handle mounted in the transmission tunnel to disconnect/connect the negative (-) cable between the battery and its grounding point. Switch is easy to reach from driver's seat and is barely noticeable when handle is removed. Mine has been in use for 20+ years and is still going strong as it is a quality product. Don't buy junk!
Received 1,581 Likes
St. Jude Donor '20-'21-'22-'23-'24
Knife switch looks like something you would find in the laboratories of Edison and Tesla. I am concerned about all that exposed metal just waiting to make an unwanted contact.
also there is a bolt that holds the terminal connector to the yellow bracket. you cannot see if it is becoming loose. it could cause the bracket to sag and make contact with the battery box when driving. another thing that happens with knife switches is the rivet on the knife loosens after years of use and the area where the blade engages the V slot loosens up making for poor contact and sometimes arcing.
#33
Received 1,533 Likes
This is the disconnect I mounted under the hood of R66. I know it is a PIA to open the hood, but it locks and they have to rip the hood off to get to it. Also handy when working under the hood and storing for winter.
Mounted it more conveniently than on the battery. Much like RatDog's.
Don't know about reliablity yet, only had it on there about 3 months.
#34
oh my!
#36
I use a Cole hersee 2484 disconnect on my c4 and also on my Gto. About $25 on Amazon.
#37
i have green one on positive side of my 67 for 10 years. No issues . Can remove at any time and connect orig batt cable. I Take green **** with me when leaving it for longer period of time on street. Never battery tend neither. Just connect when I drive and disconnect when I park.
Simple.
#39
Received 1,856 Likes
Here's the knife switch on the negative terminal on my '67 - been there for 15 years.
#40
