Can't find '65 ignition switch except Fleabay?
WTH, I thought we could find any part out there for our cars. Two vendors told me that particular switch is no longer being made??? Part # 111 66 50 ??? Hate to buy from them (129$ to 150$). Thx
The 65 ignition switch is a one year only part, and was discontinued at least 5 or 6 years ago. There is no aftermarket or reproduction of the switch, currently available.
Sullyvette (07-18-2017)
Location: About 1100 miles from where I call home. Blue lives matter.
Received 5,331 Likes
What does LICS say?
Give David Sokolowski a call 310-329-5334. He helped another forum member with a '65 ignition switch.
Received 1,843 Likes
65 Ignition Switch
I just looked in my Corvette and my non Corvette Chevy parts books. The part number was 1116660. It was used on 65 Corvette and 65 Full sized Biscayne, BelAir and Impalas. Start looking for an ignition switch for a 65 full sized Chevy---It will more than likely be much cheaper if you find one.
RON
RON
Think R66 has your switch. Check down the forum posts.
https://www.corvetteforum.com/forums...witch-i-d.html
Received 2,130 Likes
2015 C2 of the Year Finalist
Yes, I'm still having an issue with starting my '65. Tonight I went to my son's house to see his recently rebuilt '93 Turbo Toyota Supra. Started up great at my house drove 10 miles, let it sit for 30 minutes, attempted to start it to go home, nothing. Had to push/jump start it. It ran fine all the way home. My son accompanied me down Rt 20 and I have to tell you even my old Z06 woudln't touch these Turbo imports.
Back to my car, radio and lights worked, nothing when I turned key to start. I know I have to follow up on the already given advice here. I was just checking on the availability of a switch if I need one in the near future. Will do, Thx, Chuck
[/I]
Dan[/QUOTE]
[/I]
Dan[/QUOTE]
Location: Various places in California. Not currently aflame.
Okay, just want to encourage you to test a few more things--I'm sure you can find the problem. It could just be a bad connection at the firewall. I think most of us have experienced that in one way or another.
That's the ballast resister. Not involved in your starter problem. I was speaking of the two 8-pin plugs below the brake master cylinder. The inboard one includes the wire from the ignition switch to the solenoid (I believe it's the second pin from the top on the inboard side of that inboard plug).
But again, the easy way to check this is to jumper from the big terminal (where the battery cable attaches) to the S terminal (where the purple wire attaches). Just briefly connect the two--it should cause the starter to operate. Be careful, as the engine may start when you do this, so take all safety precautions--I would take off the coil-distributor cap wire so the engine won't actually start running, but you still need to take precautions as the engine should turn over when you do this.
Alternatively, you can have someone turn the key while you check for voltage at that purple wire attached to the S terminal.
If the engine doesn't turn over when you jumper it, or if there is no power to the purple wire when someone turns the ignition switch to start, then you can start tracing things back. The next place I would check is that 8-pin plug. It's a common spot for faulty connections (it caused me an intermittent charging system problem).
Good luck!
Good luck!
Sullyvette (07-20-2017)
Have you bought your $2 test light yet?
