TKO 600 Conversion Hydraulic Clutch or Not
Planning to do the TKO 600 conversion later this year. Any opinions on the use of their (Silver Sports) hydraulic clutch or stay with a conventional clutch? I also currently have a Lakewood Scatter shield bellhousing. Would it be wise to purchase SST aluminum bell housing in the likelyhood that the alignment would be easier?..Hate to lose that protection when my 383 Stroker gets wound up.
The following 2 users liked this post by wmf62:
SLWRNU (08-20-2017),
Tcheairs38655 (07-19-2017)
2021 C1 of the Year Finalist - Modified
I just ordered my TKO from them this afternoon ! I'm planning on sticking with my Lakewood and clutch linkage. Mine will go in my 60 and I told em I was going to drag race it. I will find out if the shift mods work cause I can slap my Super T-10 pretty quick..
Received 4,583 Likes
C1 of Year Finalist (appearance mods) 2019
You need to strengthen the firewall with a gusset plate if you plan a hydraulic clutch to spread the load for stress. I wouldn't bother.
Received 3,048 Likes
C1 of Year Finalist (performance mods) 2019
Here is more detail...
B/L: Hydraulic introduces a bunch of headaches or potential headaches that at the end of the day aren't worth it...
The mech linkage is fine...
Installing and reinforcing the firewall is one thing but also the fact that the throwout bearing itself is hydraulic and if it leaks the whole trans has to come out, this is the bigger issue.
I have done both...fought the hydraulic...yes mine leaked right away, had to pull it and replace the throwout bearing...
Once you get under the car and start fighting the non removable crossmember, it will become clearer...you won't want to risk having to go back and pull the trans...
St. Jude Donor '07
Bill
Tremec Conversion C-2
[B]Now it's looking like I'm going to have to raise the body to create additional clearance between the floor pans and the #2 cross member. Has anyone been through that ordeal? If so, what all is involved, how many body bolts etc.?/B]
I am now convinced that the hydraulic clutch is not a good idea. Thanks for the "leak potential" heads up.
Received 1,962 Likes
The clearance under the floor is a veryt common problem for those of us who have installed a 5 speed in a C2 - You'll need to shim the floor above the transmission crossmember using hockey pucks - lots of guys have done it!😪
Are you talking about shoving the bushings between the floor pan and the crossmember? Or raising the body with the bushings at the anchor points? Silver Sports says just shove them in there..
Tcheairs38655 (07-20-2017)
I assume you are installing the TKO yourself? It can be done with the engine in the car...I have done it this way but after doing several, I don't recommend doing it this way...mainly because I am usually working by myself.
I pull the engine, dial in the bell housing, set the clutch, mate the trans and install as a unit. These are very critical, and to get them right and doing them under the car is a b!tch.
To make the install go easier, I go a few steps further and drop the steering out of the way and remove the radiator & support so I can maneuver the engine and trans as far forward and as low as possible...then crawl under the car and lift the tail of the trans over the crossmember.
From there it isn't too bad...
One thing to consider is making your crossmember removable...there are threads to read up on...many have done this modification (myself included) and it makes the TKO install glorious...
Keep asking questions...
When mine got put in the floor bushings didn't.
Keisler later sent me their bushings. These are elongated metal "L" brackets with a piece of rubber on one side. I was able to support the floor and jack up the body enough to slip them in and I may have even put some cork on these for a bit more height. The brackets actually have mounting holes, but friction does the job.
But the tranny still hits the bottom of the ashtray.
So I took a stick and glued a piece of cork to it. I put my car up on my lift and put the stick up into the tunnel with the cork on the fiberglass. I put a floor jack under the other end of the stick and was able to jack the tunnel up enough to put some cork between that and the tranny to clear the ashtray.
BTW, mine came with a new McLeod clutch (IIRC) disk and drive shaft.
Hydraulic Clutch
It's not the hydraulic clutch I'm worried about, it's the complications of getting all of that stuff installed into a C2. It does complicate an already complicated installation (for those of us non mechanic Septuagenarians)
Might as well do it right and stick an LS 3 on the other end of the TKO 600 and lower the whole deal in. Damn the torpedoes (complications).
