Head light adjustment
One of my headlights does not completely open. It goes up about 80%. Need some help understanding how to adjust it fully open.
Did your headlight go up to full extend in the past, then your problem isn't in adjusting but your motor is gued up and in for a rebuilt.
If your headlight just goes full power to 80% and then suddenly stops it could be the Y stop adjustment but I highly doubt anyone would ever set it to that position and leave it like that.
Head light
The headlight worked well. The car went in for paint. I wonder if the painter adjusted it to partially open. I'd like to read the article that was offered. Thanks for the help.
Received 6,943 Likes
2015 C2 of Year Finalist
The adjustment is only for fine adjustment. If you spin the hand wheel can you open the door? If you can then then you need to rebuild. If you can't spin it then there is other problems
You get two for the price of one:
http://www.ncrs.org/qc/Seminars/MidY...eminar2011.pdf
