[C2] 16 inch puller fan
16 inch puller fan
Thinking to install a 16" puller fan as an added cooling source to compliment the factory fan clutch/fan when the AC is turned on. Is this viable?
The regular factory engine cooling fan works fine and is adequate under most conditions when using AC, but, on overly hot days the engine temp creeps up to 225-230 degrees in slow speed/idle in town conditions.
There's no overflow tank rumbling or coolant puking out the overflow hose at these engine temps. I'd just like to see the engine temp not go so high.
Has anyone done this..........added a puller fan to compliment a factory fan for additional cooling performance? .. If so, how did it work out? . .
John
John
John
John
I PM'd you. There is another option that I know has worked on some Corvettes that have this same issue.
DUB
If you aren't having troubles, I wouldn't worry. Have you verified the high temps at slow speeds? The sender unit may be feeding false information at higher temps.
I also have a problem (which is not borne out by any scientific process at all) with additional fans. It seems to me that they are close enough to the radiator to block air flow through the radiator at speed. I mean, if the puller fan can flow say 30 mph of airflow at a stoplight, it would seem to be a blockage at anything higher than 30. And at say 55, is the fan stationary or spinning from the air flowing and thus blocking the airflow?
Any engineers on the forum that can tell me I'm full of it? I wouldn't be offended because I already know I'm full of it...
Gerry
Gerry
Gerry
Gerry
DUB
Received 1,119 Likes
2017 C2 of Year Finalist
John
John
Received 1,581 Likes
St. Jude Donor '20-'21-'22-'23-'24
John
John
Steve
The following 2 users liked this post by 59BlueSilver:
Heeia1 (08-10-2017),
Stan's Customs (08-03-2017)
Contact 'mrg' and have 'mrg' give you the content of the PM I sent him.
Honestly....I have gotten to the point on this forum that often times when I give my experiences and suggestions to issues that I have worked out and know that has worked for me..I get some members who just want to be combative and dispute it to death. SO...I am selective on how I give out this information. It does become quite exhausting for me to have to explain everything in such fine detail so 'those' members have no way to read it any other way...but yet they still do.
I work on these cars every day and the last thing I want to do when I come home is to get on the forum.... trying to help those who ask for help...only to get otherwise. Heck...I know I am not perfect....but I do try to do the best I can to help.
I do not have the PM I sent him...and have no clue to figure out how to possibly resurrect it after I had deleted it.
DUB
DUB
Chuck Gongloff (08-19-2017)
DUB - I just want to say that I appreciate all of your postings here. I have learned a lot from you.
Take care,
Steve
Take care,
Steve
DUB (08-03-2017)
Received 1,843 Likes
Although my two midyears both still have the OEM fans/clutches on them and still work okay, I think that replacing them with a thermostatically controlled electric fan is a great idea.
It will reliably come on when the engine temp reaches a predetermined point and it will continue to blow hot air out from underneath the hood when you shut the engine off.
If I was driving my two cars under conditions some of you drive, I would make the conversion in a heartbeat.
PS. I'm not a fan of PM's on this forum to answer a question. Seems like top secrect stuff to me.
John
Gerry
Gerry
I know the conventional thinking is that you can run 210-230 all day long. But my '62 when the engine is that hot gets unbearably hot inside even though the car is fully insulated with the insulation mat under the carpet and under the dash. That much heat bakes the wiring and everything else under the hood you spent all that money on making it pretty. Not my cup of tea.
nfran (05-13-2020)
