Burning up Points and Condensor
And also failed to report the voltage on the pink wire at the coil with engine running.
Per JAVAC3
Volts at + side coil with key in on posit = 7.38
Volts at + side of coil with key off = 12.26 (same as battery)
Volts with key on (not running) at key side of ballast = 11.51
at coil side of ballast = 4.78
The coil tested at 1.8 primary and 12.3 secondary. I do have other coils I can swap in
Per JAVAC3
I keep asking you for the voltage with the engine running because it would be helpful to know what voltage the alternator is sending to the coil, not the battery.
Per JAVAC3
Received 6,513 Likes
C2 of Year Finalist (track prepared) 2019
The + side of the coil and the coil side of the ballast is the same connection (just a short wire). Why would you have a 3 volt drop on that wire? It should be the same. As tbarb said, you should have zero there with the key off. I still think you have a miswiring somewhere. Would still like to see a picture of the "noise resistor" you wired in.
I believe it connects to + side of coil and was asking for a confirmation of that.
Edited: The noise suppression capacitor attaches to the positive terminal on the coil. I had to look at my pictures from times past, my memory was not as accurate as the pictures were.
You have voltage to your coil fulltime it appears, which burns up the points; prob when the car is sitting and the points are closed, then when you drive it the malfunctions start.
its the same as leaving the key in the ON position instead of ACC for a long time..
Not only that but this makes your car incredibly easy to steal...
You have some really bogus wiring...get help...
In this picture from the AIM, it appears that it is connected to the positive terminal on the coil.
Since you seem to be having these problems since you added the capacitor, I would unhook it and see if your troubles disappear.
#33
Won't matter. Constant voltage at the coil in key off position is wrong no matter what you put on there. The Fink explains how it burns the points. I'm surprised it doesn't drain the battery too.
#34
OP read and internalize the above sentence. Several people have pointed this out. You really ought to find out why you measure Voltage at the coil with the key off before you just throw parts at the problem.
#35
OK 65GGvert will be happy.
I replaced the coil with a spare 202 and idled the car in the garage. Voltage readings as follow:
11.65 to ign side of ballast resister
7.70 on coil side of ballast resister
7.70 on + side of coil
3.8 on - (points) side of coil.
NO voltage readings on coil with key off
4.84 on + side of coil with key in on posit but not running
Voltmeter is all over the scale on - side of coil with key on but not running.
#36
#37
mea culpa on the previous high voltage at coil. I confused the cars, and was using + on the battery thinking it was ground......duh
ballast is finger burning hot, but car is running. Roadtest will reveal if coil was problem......or if a need a tow home.
#38
If your latest voltage readings are accurate, then your wiring and ballast check out AOK, and the problem is a failing coil. Other than oil leaks, the first sign of a failing coil is non-function when the engine gets hot. Your engine displays classic symptoms of a weak coil. If your replacement 202 is an original one, then make sure to have a brand new coil in your car as a spare. Buy a generic replacement labeled: "use with external ballast resistor" from your local auto parts store.
#39
#40
Oh yes - the ballast resister does get hot. That's what electrical resistance develops - heat.
