1966 air conditioner question
Factory A/C on my '66 BB can run great, cold, when it runs, but sometimes, for no apparent reason, it blows hot, but moments later if you've turned it off and you try again, it works fine. Doesn't change from hot to cold or cold to hot once it's decided where it wants to run. So, once running, it stays in that mode. It only fluctuates when it's been off, then switched on again. As you can imagine this is hard to trace. Any thoughts here? Obviously, it's full charged, or it wouldn't be cold, ever. thanx steve
Received 6,943 Likes
2015 C2 of Year Finalist
Have you checked the hot water shut off valve or the vacumn switch on top of the heater box?
steve meltzer (07-26-2017)
My money is on a sticking STV valve (or perhaps POA valve if you changed over to it). That is where I would concentrate my efforts.
Larry
thanx so much for your ideas. i'll post when solved. thanx. s
Not sure who put my AC system together years ago, tho' it works great under normal circumstances....replaced the heater fan resistor (common GM part) and the cycling switch/valve (from a 2000 or so Chrysler!!). Working great now. thanx steve
didn't specifically test that, but, if it fails again, I will. So far, so good. steve
