Key ignition cylinder
Does anybody replace key ignition cylinders? My 86 is sloppy, and won't start. Over recent years the VATS would think someone was stealing car and wouldn't start, but now it totally doesn't want to. In Yamhill Oregon.
Normally if you buy the cylinder from a GM dealer they will key it to match your key for you since their cylinders come blank.
Bill
A local locksmith rekeyed my replacement ignition switch to match the original key for $9 (nine dollars)..
Over here, we don't know nothing bout no 86 VATS systems. I agree the resistor is in the key, but the contacts that read it are in the cylinder. So......better off in C4 forum probably.
