1955 hood release cable
Currently I have to put my car on a lift and push a bar into the latch to pop it. This is not convenient. Has anyone replaced the hood release cable? Anyone know where to buy one? What years fit my 1955? Thanks in advance.
you could try Grossmueller's. If no luck, I have a driver quality hood release that I removed from my 55. it performed perfectly and was only replaced because I had a restored one for judging. $250
Received 6,513 Likes
C2 of Year Finalist (track prepared) 2019
I don't want to go thru what the OP has to go thru should the hood release cable ever stop working on my '54.
So, what I've done is to attach a couple of lengths of coathanger wire to the hood catches in the engine bay. The lengths of wire pass thru the firewall and are bent into loops which I can easily grab. If the original hood release cables ever break, I can grab the coathanger wires and still manage to open the hood.
A bubba kluge, to be sure, but it works.
Jim
Jim
Received 1,421 Likes
C1 of Year Finalist (stock) 2019
2018 C1 of Year Finalist
The hood cable can be rebuilt
If your interested I can get you the persons name.
He rebuilds hood cables, choke cables, and heater cables for 53-55
single pull 54 and 55 are the same
