[C1] How to lay down creased/folded carpeting?
Hi All
I was able to purchase a set of brand new replacement carpeting for my 60 from a shop that apparently bought the carpet set for a customer and then it was never installed. It is "new" in the box, but since the pieces have been folded to fit inside the box and then it sat on the shelf for many years, the carpeting has folds and creases. Also, the rubber backing is starting to dry out a bit making the pieces less flexible than a newer set fresh off the assembly line.
My question is, besides laying the pieces outside in the sun for a few days, is there anything recommended to flatten the pieces before I install them? I was also planning on using contact cement on both the backing and floor to keep everything in place and hopefully smooth the pieces out the best I can.
If anyone on here knows of a solution to take out the creases and folds please let me know. I am planning on pulling everything this weekend and installing the set.
Thanks!!
Ted
BTW, the carpet set only cost me $55 shipped so I couldn't pass up this deal!!
Thanks!!
Ted
Mine was in the box for over 15 years. I laid it out flat and the creases slowly went away just like when you move a piece of furniture on your carpet at home. However, the backing had hardened and is crumbling.
Received 6,517 Likes
C2 of Year Finalist (track prepared) 2019
Steam is good.
My technique is to lay a very moist towel over the wrinkled area and then use an iron on the towel to create the steam. Works every time.
Is there some thing I can apply to the rubber to keep it flexible or is it past rejuvenating and I should just flatten out the folds I can, secure it with contact cement and call it a day?
My carpeting is the original set that I reinstalled after bought my car (I reassembled the entire vehicle that was in parts) and it has lasted me this long although sections under the gas pedal and along the center console/firewall have been deteriorating for years due to the heat.
Thanks,
Ted
Thank you to all who posted. Now that this member brought this up, I noticed on the parts where the creases are, the rubber backing has cracked and started to harden. I don't have large pieces of the rubber breaking off yet, but I supposed it is to be expected that this will happen over time.
Thanks,
Ted
Thanks,
Ted
New carpet requires NO glue...none IMO. Here's how you do it (attached PDF).
