1963 Front License Plate Holder Question
Can anyone advise what parts (correct parts) are needed to affix a from license plate to a 1963? Also a good source for the parts? Just bought a 1963 convertible up at Corvettes at Carlisle. Thank you in advance!
Here's the holder... with the small holes, 1/4 inch IIRC.
You'll need the plastic inserts to go into those holes. You'll need the correct license plate mounting hardware to mount the plate, IF you're doing a NCRS type resto.
You'll also need two bolts/nuts to mount the holder/bracket to the crossbar. Those bolts have specific headmarks, again IF you're doing a NCRS type resto.
http://www.zip-corvette.com/63-65-fr...0aAtY5EALw_wcB
Thank you
Chuck, Thank you for your quick response! Appreciated! Bill
I leave the front plate off. I think it may block some air getting to the radiator, but maybe not.
