[C1] 58 Single Carb - Opinion Asked
Just looking for a general consensus on what is more apt to be the problem when the engine only after fires (or backfires) on deceleration. IF its isolated to the fuel mixture, is it because it is running too rich OR is too running too lean. Seems I get mixed reviews from people I have asked at car shows.
Received 6,939 Likes
2015 C2 of Year Finalist
I double check your timing
Just another Corvette guy
Bomba, is your backfire through the exhaust or up through the carb?
After fire in the exhaust pipe is timing or a lean condition in most cases. Make sure your exhaust manifolds are tight. .
Did you just check the initial timing or did you also check the advance curve through the RPM range. Double check your dwell at the higher RPMs also. If you have a vacuum advance, double check that the advance diaphragm can hold vacuum and not leak.
An old saying that I have found to be true more often then not - most carburetor problems turn out to be ignition problems.....
Tom
Tom
I'm with FTF, I would look at the ignition system.
Mechanical advance curve and vacuum advance. If you are not 100% sure of the two advance systems have your distributor checked by a competent shop.
My 2 cents
My 2 cents
Look for a vacuum leak, back in the 50's we used to induce a vacuum leak, usually by pulling off the windshield wiper hose, to make it "rattle" off good when backing down.
Bill
Bill
It sounds like a ford thing. my 55 ford vic would pop and pop going down a long hill. I"ts caused by an exhaust system that is not quite as tight as it should be. No harm ,Enjoy the noise . It is a sports car
