clutch and brake firewall bracket..Q
C2 of Year Finalist (stock) 2019
ok, i am going through my parts too put together my pedal asem. i screwed up and tossed it all into a crate with other asem. i know the power brake pedal asem only has 2 bolts holding it too the firewall. and the booster has studs with nuts on the inside. i know the brake pedal has the extra tab bracket mounted on it too hit the brake switch. i got all that.
Q-1, i looked at the AIM and there is no directions on weather there is a spring still on the brake pedal, like the none power does. should there be?
Q-2 is the firewall PB mount the same as a none power brake mount, just the bottom studs knocked out?
give me your thoughts guys ...thanks troy
Received 1,856 Likes
2. Yes. The bottom pair of pressed-in splined 3/8"-16 mounting studs on the manual brake pedal support bracket need to be knocked out so the two studs on the booster can go through those holes and get nuts from the inside. In production, the pedal support for power brake cars came to the plant under a different part number, without those two studs.
20round (09-23-2017)
