I don't believe there is. Once the factory burned in St. Louis, all of the info on C1 and C2s went with it.
If you have the Protecto-Plate for your car, go to the GM Heritage website and you can figure it out.
As I understand it, only 67s had a tank sticker.
Maybe JohnZ will correct me if I am wrong.
There is the trim plate next to the VIN plate under the glove box. It tells you some things like the interior and exterior color. No engine or other option info, though.
The "fire at St. Louis" is a common misconception - there was no fire. People have no idea how much paperwork each car required, and that little assembly plant had nowhere to keep it, nor did any of the full-size assembly plants. They were designed to build cars, not to store paperwork. Most of the data was stored electronically at Chevrolet-Central Office in Detroit, and pitched after it served no further business or tax purpose.
R66 is correct - there was no "tank sticker" until 1967.
Thanks John!
I guess I am still young enough to be a student and learn a thing or two. Now if I can just remember what I learned.
