[C1] Rpo 684
Old 09-29-2017, 02:17 PM
Marcrpo684
Marcrpo684's Avatar
Default Rpo 684
I am new to the forum and would like some guidance on the value of parts I have. The parts were on a Devin I bought and after some research they seem to be the big brake option RPO 684 from a 1959. They are complete but I think the front backing plates are not proper, they have drilled holes in the backing plate versus the mesh ones in the rear.. The setup seems to be in good condition and I verified that the wheels are original 15 x 5 1/5 big brake wheels and the brake pads are metallic with 4 pads and 2 pads . It has Rochester fuel injection dated 1960 with the distributor. It also has what looks to be a 1959 t-10 4 speed. It has a narrowed corvette rear with positraction. The frame is not corvette. It seems to be a shortened and narrowed tri 5 chevy frame.I think the parts would be better served to be put back on a corvette. I would like some guidance on what they are worth.
Thanks,
Marc
Old 09-29-2017, 02:46 PM
emccomas
Support Corvetteforum!
emccomas's Avatar
Received 1,283 Likes on 732 Posts
Big brake, big wheel, FI car.
The 5 1/2 inch Kelsey Hayes wheels are worth a small fortune. Do you have a set of 4? I have seen a set of four sell for $10K, and one person was asking $15K for a set of four. I think these may have been NOS.
Take lots of pictures of ALL of the parts, including any numbers on the parts.
What motor was in the car?
The following 2 users liked this post by emccomas:
jimgessner (10-03-2017), Marcrpo684 (09-29-2017)
Old 09-29-2017, 03:21 PM
63Corvette
63Corvette's Avatar
Cogratulations! Sounds like you have a great, LEGAL Vintage RACE car there
The following 3 users liked this post by 63Corvette:
jerry gollnick (09-30-2017), jimgessner (10-03-2017), Marcrpo684 (09-29-2017)
Old 09-29-2017, 03:37 PM
Marcrpo684
Marcrpo684's Avatar
I have 4 wheels and they seem in excellent shape. They have vintage dunlop racing tires on them, unfortunately the tires are dry rotted.
The motor in the car is a 283. It does not seem to be the original block numbers are 1903f heads 3731554 H 1357
Old 09-29-2017, 03:40 PM
leif.anderson93
leif.anderson93's Avatar
Received 3,098 Likes on 1,866 Posts
Would love to see some pictures of the Devin itself...super cool cars
Old 09-29-2017, 03:49 PM
Marcrpo684
Marcrpo684's Avatar
Default Pics of the Devin
Here are some pics of the Devin being extracted from the barn.
An interesting possibility is that a late 1959 c1 with all these options on the Devin was wrecked in a hillclimb not 10 miles from where I found the car.
There may be a chance that the builder of the car (deceased) bought some of the go fast goodies from the salvage yard. The 59 C1 blew a motor in 1962 and this has a replacement short block. The fuel injection number is 3008 p[art # 7017320.
Old 09-29-2017, 03:53 PM
leif.anderson93
Very interesting find. What are your plans for her?
Old 09-29-2017, 04:01 PM
Marcrpo684
Marcrpo684's Avatar
Not sure yet. Thinking about selling off the rare parts to someone restoring a car that could use them and then restoring the Devin with more common parts of that era.
Possibly sell the Devin the way I found it. It seems to have been built somewhere in 1963 range and was raced as a C Modified at Springtown Hillclimbs, from what I can find the last Springtown Hillclimb was 1968 and has been stored since then.
Old 09-29-2017, 06:36 PM
emccomas
emccomas's Avatar
You can do a lot to that Devin for what you can get out of those wheels, the big brake parts, and the FI system.
Obviously condition and completeness of the parts will factor into the value.
Get a complete inventory and lots of pictures of these parts. You will not have problem selling them.
Old 09-29-2017, 09:00 PM
Marcrpo684
Marcrpo684's Avatar
Do you think eBay is a good place to sell the parts?
Old 09-29-2017, 09:27 PM
leif.anderson93
I would start by posting them up here and, also, over on the NCRS site. They'll be gone very quickly. No need to mess with eBay.
Old 09-29-2017, 09:46 PM
Marcrpo684
Marcrpo684's Avatar
Thanks, I'll take more pictures and post them here so hopefully I can some advice on a fair price to ask.
Old 09-30-2017, 03:39 PM
emccomas
emccomas's Avatar
Post the pictures and get recommendations on asking price.
Old 10-02-2017, 01:52 PM
Marcrpo684
Marcrpo684's Avatar
I took pictures of the stamped numbers on the brake drums and wheels. Also of the casting numbers and data plate on the transmission.
Are there other numbers on the brake parts I should look for ie: wheel cylinders, brake shoes and differential?
Old 10-02-2017, 02:04 PM
emccomas
emccomas's Avatar
Yes, get pictures of EVERY number you can find. Make sure you identify the part that is associated with the number (i.e wheel cylinder # 12345678). Post everything, including large scale pictures of the entire part, then the detailed pictures with the numbers on them.
Make sure you get the numbers from the inside of the wheels as well. If they have old titres on them, get the tires off. The numbers on the inside of the wheels are important.
Marcrpo684 (10-02-2017)
Old 10-03-2017, 08:16 AM
emccomas
emccomas's Avatar
What is this number on the wheel? You need the numbers from all four wheels?
Old 10-03-2017, 08:36 AM
emccomas
emccomas's Avatar
OK, I have done a little research on your parts...
My rough estimates are:
The 15 x 51/2 inch wheels - $1750 to $2500 per wheel (need to list all of the numbers on the wheels).
The 7320 Rochester Fuel Injection System complete with distributor - $3500 to $4000 as is (again, list all of the numbers).
The 1959 4 speed T-10 transmission - $300 to $400 (assuming rebuildable, and list all numbers)
Big brake shoes,good used - $100 to $150 each
Big brake drums, good used - $750 to $1000 each
Big brake backing plates, correct with mesh - $600 to $800 each
Not sure what else you have at this point.
Low estimates
Wheels - $1750 x 4 = $7000
Rochester FI system = $3500
4 speed transmission = $300
Brake shoes - $100 x 8 = $800
Brake drums - $750 x 4 = $4000
Brake backing plates - $800 x 2 = $1200
Total low estimate = $15,800
High estimates
Wheels - $2500 x 4 = $10000
Rochester FI system = $4000
4 speed transmission = $400
Brake shoes - $150 x 8 = $1200
Brake drums - $1000 x 4 = $4000
Brake backing plates - $800 x 2 = $1600
Total high estimate = $21,200
Nice find, good luck with the sale
Marcrpo684 (10-03-2017)
To Rpo 684
Old 10-03-2017, 10:38 AM
gbvette62
gbvette62's Avatar
Received 2,022 Likes on 1,312 Posts
Congratulations, that is a very cool find!
Since you say the car ran the Springtown Hillclimb, I'm guessing the car's in PA, or at least once was? Those PA hillclimbs (Giants Despair, Duryea, The Pagoda, Weatherly, and others), were great events. Springtown was in Bucks County PA, and although I've occasionally heard rumors about efforts to revive it, I think they last ran there in the 60's.
Before doing anything with your Devin, you might want to track down some more history on the car. The PA Hillclimb Association is still promoting events, and may be of some help in documenting the car's past. Depending on what you find out, it may make sense to keep all those early Corvette parts with the car. http://pahillclimb.org/
You might also want to try to contact Dave Zavestsky of Wellsboro PA. Dave has a beautifully restored 59 Devin-Chevy, that he regularly vintage races here in the Northeast.
This is Dave's Devin 283 at the VSCCA/VRG race at Thompson Speedway, back in June.
Old 10-03-2017, 10:45 AM
Marcrpo684
Marcrpo684's Avatar
Low estimates
High estimates
Thanks for the pricing. I was thinking about selling the brake assemblies as one lot, the wheels as a lot and the fuel injection as a lot. Does it make sense to have the injection restored?
Does it make sense to sell the brake system as a package?
Old 10-03-2017, 10:47 AM
Marcrpo684
Marcrpo684's Avatar
Thanks for the advice and pics of the car. That is a great looking race car, exactly how I would like mine to look.
Quick Reply: [C1] Rpo 684
