54 corvette dash rail cover
I agree 100%. That is the best way to get it done right and with the least amount of frustration. The cost plus shipping is well worth it, and you can get lots of other stuff done with all of the time you will save yourself.
I did mine on my '57 last year. Not rocket science, but it is a little tricky. First make sure the material is warm by setting it in the sun for a while, or carefully using a heat gun. I found that the contact glue I used that was supplied was a little thick and would ball up a little if you re-positioned the material. That would show through as little bumps, so I'd have to peel it back again and take some solvent to it to get rid of them and glue it again. If I were to do another one I would try using the 3M spray adhesive on the face of it, and use the contact cement on the backside to glue the excess. You mark the material and dash rail centers, and work from there out, but the ends were a battle to get slipped over, and I used the heat gun carefully there. I am happy enough with the way mine turned out, although I have a couple of minor sins. I have seen far worse ones on restored cars in pics online.
I guess it depends if you have the time and want to try it. I debated, as the cost is not that much, but I wanted to give it a go, as I am a glutton for punishment.
Rich
Rich
