Factory Powe steering compared to Borgeson
Shame on me- I admitted to Lou I haven't gotten around to rebuilding my control arms and installing slotted cross shafts for the extra caster the Borgeson wants.
If you don't do this with the swap you will be driving a car that feels "over assisted" until you do.
Not a negative just a word of caution.
Benton
Benton
IIRC Borgeson recommends 4*, but mine works just fine at this setting. No "overboost" sensation at all.
i do like hearing your experience
What I'm calling a dead spot probably is what Glenn describes as the system being over boosted at dead center. Whatever it is, I've never liked it in Vettes of that vintage even when they were new. Besides it's nothing we can quantify, just a matter of personal preference. I recall driving a new '63 Impala on a geology class field trip and the steering was so light it was frightening on the highway, as so many American cars were back then; but they kept building them that way for a long time, so I'm in the minority about how I like steering to feel.
for the last car I used a very well known vendor and I could not be happier with the results. how any one can compare a worn out system to something that is new is beyond me.
and can someone please tell me on 67 cars if you collapse the column in order to make that aftermarket box fit how is that not a safety concern. plus you can not buy the parts to fix the column if you want to go back.
I don't fault anyone for making the upgrade, it's just not something I would do. Cutting the steering shaft, installing different pulleys, pumps not bolting up properly. (I REALLY DID READ THESE THINGS HERE).
It's really interesting how folks who do not own a '67 and/or have not done the conversion can be such harsh critics of it.......
Randy G. (10-21-2017)
Received 6,928 Likes
2015 C2 of Year Finalist
And while I can't remember what the last caster setting was, it was set at the high limit.
Sounds like you already have your mind set what your going to like.
I would guess I could pull the Borgeson unit and reinstall the factory unit in about 3 hours!
Bob
tuxnharley (10-19-2017)
Do you have any direct personal experience with a Borgeson conversion, or - as you have said in previous posts - is it all just based on what you have read?
Yes, it is very easy to revert back to the factory power steering, and you do not cut the steering column shaft - just tap the end of it gently - it will need to be about 2 or 3 inches shorter. And once you get it collapsed, you'll find out you can lengthen or shorten the column fairly easily. It's a shaft within a tube. You do not lose any collapsibility - that is determined by a crush zone located near the top of the column - you can see it under the instrument cluster where the column is mounted with three bolts.
Bob
Bob
#34
We've had this thing up on my lift trying different settings and different setups on the power steering and front end and we've also done a basic 4 wheel alignment check on it and all I'm going to say is at 70 miles an hour on a freeway cut with lines and the grooves that are meant to eliminate hydroplaning, this car hunts all over the place and you better be paying attention. So far people with back-to-back experience on the two setups are saying exactly the same thing I'm feeling in my '67. At 70 mph freeway speeds the steering is too sensitive to any corrections or input you give it through the steering wheel. On asphalt at speed it's significantly better, but we don't have many asphalt freeways here.
#35
The steering shaft (item 20) is a two piece shaft - the lower section simply slides into the upper section. In an impact, the crush zone (shown on the right side of the mast jacket - item 3) collapses and the upper section of the shaft simply slides into the lower section.
Bob
#36
if your moving something in the column or part 20 something has to give. I would like to see a drawing for the shaft. its too bad Jim Shea's web site is down
#37
If this is intended for me the answer is no.
#38
All my classic car buddies have Mercs, Cuda's, Mustangs and shoebox Chevy's. There are a few C2's at some of the shows I go to but none have factory power steering. One guy has what looks like a Steeroids rack and pinion and the rest have manual steering. That's why I asked everyone's opinion here because there are more c2 guys here than anywhere else on planet earth.
#39
I would say there is something afoul with your car. either a worn steering box, alignment problems or the P.S. valve is the wrong one or wore.
the shoe box chevys used the same style PS set up. if your question the PS valve I woiuld send it to Lone Star for a rebuild
#40
Since you are so terribly concerned about the supposed negative impacts of installing a Borgeson conversion on a '67 Corvette, I would strongly recommend that you not install one on yours.
Oh, wait......
Oh, wait......
