Factory Powe steering compared to Borgeson
Old 10-19-2017, 08:23 PM
  #41
Nowhere Man
Nowhere Man's Avatar
Received 6,920 Likes on 4,770 Posts
2015 C2 of Year Finalist
Originally Posted by tuxnharley
Since you are so terribly concerned about the supposed negative impacts of installing a Borgeson conversion on a '67 Corvette, I would strongly recommend that you not install one on yours.
Oh, wait......
I wont its his car he can do what he wants.
Old 10-19-2017, 09:49 PM
  #42
JohnZ
Support Corvetteforum!
JohnZ's Avatar
Received 1,856 Likes on 1,099 Posts
Originally Posted by R6T7
I'm not sure what plastic pin you are referring to - there is no pin in a '67 steering shaft -
Yes, there is. The steering shaft (item 20) was manufactured at Saginaw Steering Gear as an assembly - the inner shaft and the outer shaft, with a telescoping double-"D" joint, with a hot-injected nylon pin filling the hole drilled through both shafts. This was the standard '67 GM column design, not just on Corvette.
tuxnharley (10-20-2017)
Old 10-20-2017, 07:38 AM
  #43
Nowhere Man
So John would that compromise anything in the column if someone would hit the shaft to gain the clearance required for this aftermarket steering box. I know there was a recall on 67 Chevelle columns for something with that plastic pin
Old 10-20-2017, 10:44 AM
  #44
426 Hemi
426 Hemi's Avatar
Hey - even Captain Picard refused to be assimilated by the Borg!
Old 10-20-2017, 12:05 PM
  #45
tuxnharley
tuxnharley's Avatar
Received 1,937 Likes on 1,183 Posts
Thanks, John. That's an interesting piece of manufacturing history.
What was the purpose of the "pin"? I can't imagine it held much structural or shear value, and the two piece column was clearly designed to slide freely and shorten in the event of a frontal impact with strictural/frame damage.
My guess is that the pin was just intended to hold the two column pieces in a fixed configuration during shipping, installation, or both, and had no intended value during operation of the vehicle.
I see no downside to having temoved it to shorten the column during installation of the Borgeson box.
Your thoughts, please?
Old 10-20-2017, 12:14 PM
  #46
R6T7
R6T7's Avatar
John, I stand corrected - when I had mine apart there was no evidence of that pin - of course who knows what may have been done to the column. I assume the pin was to aid in vehicle assembly - but not likely to affect it's function in a crash?
Bob
Old 10-20-2017, 12:41 PM
  #47
Randy G.
Randy G.'s Avatar
I can't imagine Chevy putting a plastic pin in a steering column would be considered a major component of the assembly, but there must have been a reason they put it in there. After all these years I wonder how many haven't somehow broken anyway.
Old 10-20-2017, 05:14 PM
  #48
wmf62
wmf62's Avatar
St. Jude Donor '07
I suspect the pin was to prevent handling or shipping damage prior to installation. once installed it should make no difference is the pin is sheared.
Bill
Old 10-20-2017, 05:31 PM
  #49
Nowhere Man
Bill
There was a recall on 67 Chevelle columns due to plastic pin So GM thought it was important enough to have a recall in 67.
Old 10-20-2017, 06:10 PM
  #50
tuxnharley
tuxnharley's Avatar
Who lnows. That recall could have been for just the opposite reason, say too much nylon injected that interferred with the collapsibility. It's all just speculation at this point. If one wants to imagine a problem there are lots of possibilities.
One thing is for certain - the lack of that little piece of plastic in no way detracts from the design function of of a collapsable steering column. I'd be much more concerned about a solid shaft in a pre '67 than nitpicking this.
Old 10-21-2017, 05:27 PM
  #51
JohnZ
JohnZ's Avatar
I'm sure the injected pin was only there as a handling and assembly aid at Saginaw to maintain the design overall column length while all the other bits and pieces were added to make up the complete assembly as-shipped. The energy-absorbing function operated in three stages. On impact, the plastic pin sheared, and the lower shaft moved rearward about 2", until it bottomed-out on the lower end of the upper shaft. In the second stage, the perforated metal column outer tube (hidden under the tubular plastic sleeve) collapsed, and in the third stage, the plastic-injected pins in the three column-mounting ears sheared and allowed the column to move about another inch or two.
The injected pin through both shafts played no part in the actual energy absorption sequence.
The following 3 users liked this post by JohnZ:
65air_coupe (10-27-2017), R6T7 (10-23-2017), tuxnharley (10-21-2017)
Old 10-21-2017, 05:46 PM
  #52
Nowhere Man
Thanks. So it seems I was over thinking this. I still wouldn’t do it myself but it seems if you chose to it won’t hurt to much.
Old 10-21-2017, 06:19 PM
  #53
65 396
65 396's Avatar
Not in my case. ZERO issues in two years now.
2X with tuxnharley
Quick Reply: Factory Powe steering compared to Borgeson
