C2 (1964) Radio wire connection
Old 10-25-2017, 06:57 AM
Jim@useaat.com
Cruising
Jim@useaat.com's Avatar
Default C2 (1964) Radio wire connection
What are the wire color from the harness and there color?
How many wires are there from the harness to the radio?
Old 10-25-2017, 07:20 AM
Frankie the Fink
Frankie the Fink's Avatar
Received 7,082 Likes on 4,736 Posts
Army
There is power, light and ground.. Red, green and black, respectively, going to my aftermarket radio - so, you can figure out the color code on the other side at the factory harness.
There is an L-shaped connector to the speaker - you can't get that wrong.
Jim@useaat.com (10-25-2017)
Old 10-25-2017, 07:45 AM
65GGvert
65GGvert's Avatar
Received 3,205 Likes on 2,297 Posts
There are a total of four wires on the car side of the plug. Two black in the middle for ground then one side 12 volts when key is on, the other side 12 volts when lights are on . Usually the light side is grey and the power side is yellow but as you can see from Frankie's picture it could also be brown. It can also be black with a yellow stripe just measure for voltage when the key is on on one side or the other beside the ground that's in the center.
To C2 (1964) Radio wire connection
Quick Reply: C2 (1964) Radio wire connection
