[C1] 1960 front measurements
Can someone send me a few measurements on the front corners of a 1960. My driver side (L) front corner appears lower than the passenger (R) side by about 1". I know my frame is true - all frame specs are ok) and nothing else obvious can be seen (shimming seems ok all around), shocks, springs tire pressures all seem similar. I suspect the issue at the radiator but bolts on each side seem to lineup (which may be the problem). I think they need some 'tweaking' to bring the left body side up slightly or the right side down slightly (or a bit of both).
But I need correct heights to reference as a starting point (assuming similar tire pressures etc.,) Can someone measure from ground to centre of corner bumper (which will match the center of the bumper mounts through the body) on each corner and / or to the bottom of the headlight bezel on each side?
This will be a great starting point to determine what I need to adjust.
slyguy (12-27-2017)
Anyone reading who can take the time to send the measurements from this thread would be grtly appreciated.
thanks,
I would take a measurement from the top of each rim at the top to a level surface on all 4 corners
Then take a measurement from the center of each wheel arch to ground this should give you a good start of which corner in high/low as compared with other side/corner
Let us know what you find
slyguy (12-27-2017)
thanks
Read this post:
https://www.corvetteforum.com/forums...any-ideas.html
In post #37 I posted a picture showing the curvature of the top of the fender.
Charles
Charles
slyguy (12-27-2017)
Thanks Charles, that will help. Btw, can you briefly say how the heck you set up to get set accurate measurements? That whole 'fender droop' thread is very interesting. I'm still not convinced I'm not a mounting issue or that my left side even runs high (as apposed to the right drooping) possibly from a previous glass issue (that I can't see wo removing inner fenders).
I'm on hold under a foot of snow and -20º, so even w heat, my garage is not the best place to be right now. In the meantime, I'd still really appreciate someone - anyone who can provide the front end measurements at the beginning of this thread,thanks again C
Just in the last week or two there was a post with measurements. I'm surprised someone has posted a link I would but I'm old and forgot which thread it's in.
slyguy (12-27-2017)
Charles
slyguy (12-27-2017)
Makes sense. I'll do the same (as soon as garage warms up), and post up what I get. If I understand correct, I assume you subtracted the height of the wood block from your measurements? I'm all 4's on dolly wheels for a while but that shouldn't matter as floor is perfect level and all dollies are =. It's a start. Thanks.
Received 3,048 Likes
C1 of Year Finalist (performance mods) 2019
I don’t understand your comments regarding the radiator and what bearing it has on any of this?
slyguy (12-27-2017)
You keep going back to your original request for those particular measurements which I can understand but you are new to the forum and I suggest you listen to the responses you have gotten.
Thanks for your input. I have listened to all responses. Sorry for your confusion - the fg cracks emanate from the area around the body connects at the rad support, suggesting investigation in that area. As for my original request, guess i had no idea it would be so difficult to get the measurements.
slyguy (12-27-2017)
Took some quick measurements for you while I was out there working today from my 59 which should be the same as yours:
Floor to center of bumper 18"
Floor to top of headlight door 32"
Body behind wheel well to floor 8"
Both sides were dead on even on my car which had front end completely rebuilt and NOS correct GM springs.
Those dimensions correspond to your drawing on mine which is a no hit original body. How do your front bumpers align in relation to the body on both sides? Pilot Dan
slyguy (12-27-2017)
Charles
slyguy (12-27-2017)
Thanks 68 Hemi, while I was writing you I received from Pilot Dan my response is there. Yes, the fg cracking is in front of the rad at various seams - which is why I suspect the rad support mounts and or inner fenders - but until i got the #'s from PD, I wasn't sure which side to focus on. And the main concern, besides aesthetics is problem of bumper mounts. Looks like I start my investigation on the passenger side (once my garage gets above 0º) Thanks again, for your time on this one.
The height of my block makes no difference. The horizontal (level) line is just a datum plane. The measurements could be taken from any height as long as the line was level. You have to utilize the vertical measurements in relation to each other, not the datum line.
Charles
Charles
