ralley wheels
ralley wheels
I just purchased a 64 roadster that appears to have 63 corvette hubcaps on it I want to put ralley wheels on it.I know they came with 6 inch wide ralleys Can I put a 7 inch wide ralley without it rubbing and if so what backspacing?I would appreciate any input!! Thanks
Enjoy while you can.
Received 2,685 Likes
Ohio Events Coordinator
C2 of Year Finalist (stock) 2019
St. Jude Donor '14-'15-'16-'17-‘18-'19-'20-'21-'22-'23-'24
St. Jude Donor '17-‘18-'19-'20-'21-'22-'23-'24
Welcome to the Forum and congratulations on your '64!
dahogan has steered you the correct direction for the best answers on this. You'll find lots of good info on the C2s there.
Received 1,679 Likes
Welcome to the CF!
Received 19,293 Likes
'20-'21-'22-'23-'24
Moved to C1 & C2 Corvettes section.
Yes, by all means, welcome to the Corvette Forum.
If you can find a set of '68 Corvette Rally wheels, AG code, 15"X7", backspacing of 3-3/4", these should work on your car. If you know someone with a '68 (and original wheels, many were early on swapped for 15"X8" rally's) see if you can borrow one and see how it clears.
You'll find some additional discussion in this thread as well.
https://www.corvetteforum.com/forums...tire-size.html
Good luck... GUSTO
Good luck... GUSTO
I have a set of 69 Z/28 15x7 wheels mocked up on my '64 and they do NOT clear in the rear. I think they are 4 1/2" backspace so you need the corvette offset mentioned above.
2023 C1 of the Year Finalist - Modified
2022 C1 of the Year Finalist - Modified
2020 C1 of the Year Finalist - Modified
2019 C1 of Year Finalist (performance mods)
2018 C1 of Year Finalist
Welcome to the forum! We want to see pics of your new 64!
