c1 engine temps
c1 engine temps
No one says they cant get their corvette to run hot enough , since my latest freshening up of my 327 CE standard bore motor any temps above 140 don't exist ,
over the weekend I installed a 160 high flow thermostat . and still low reading well time for a 180 and ill see what happens , the car does not warm up enough for good tuning conditions . the water pump I installed was a napa brand pump the radiator is stock alum dated 1965 .
Received 4,551 Likes
2016 C2 of Year
2015 C3 of Year Finalist
Have you confirmed the temps with an IR gun? Sounds like it's too low to be accurate. May be a gauge/send unit problem. I would run a 180. A 160 thermostat will cause it to run cool in the Northeast during temps under 50 degrees. In the summer it will still take the temps to where the car wants to run.
I have the same problem in the winter. I just put a piece of cardboard in front of the radiator. You will need to experiment to see how much of the radiator needs to be blocked.
Received 1,295 Likes
2022 C1 of the Year Finalist - Unmodified
2021 C1 of the Year Finalist - Unmodified
2019 C1 of Year Finalist (stock)
2016 C1 of Year Finalist
That should not be necessary when using a thermostat though... right?
Correct.
The blocking the radiator method was done in the 1930s and before when cars didn't have thermostats. if you have a working thermostat and didn't dick with it by drilling a bunch of holes in it, you don't need to block the radiator
The owners manual for my 1933 Chevy Roadster states to block the radiator and close the hood vents in cold weather and open the hood vents in hot weather. (Thermostats were an add on accessory and were not supplied with the car). And in weather below 20*F, to add 1 quart of kerosene to the oil sump to help thin the oil.
Edit: The hood vents do work as designed, as the engine compartment is mostly blocked off underneath to prevent air from escaping unless the hood vents are open.
Doug
Doug
ironheadvette (11-15-2017)
My 61 hung right in at 175* to 180* all day, every day. Its an odd one that runs TOO cool...usually the opposite. I'd confirm the sending unit for sure.
Tether Man
Received 2,014 Likes
2019 C1 of Year Finalist (appearance mods)
