[C1] '61 convertible top hold-up straps installation
First an important item. The rear bow is non-magnetic which I'm thinking means that it's a reproduction. In reading JohnZ's detailed explanation of 5/8/2002 I'm unable to find the t-nut. Can anyone post a good picture or two for this? I know that other posts indicate that for some years reproduction bows need modification.
Should I just put the snaps in and leave well enough alone especially since any points deduction will likely be minimal? I could of course drill and tap if that would be a good idea.
Thoughts?
Thoughts?
Thoughts?
Thoughts?
The attached PDF of Rich Mozzetta's work on the repro rear bow probably contains info you can use.
Dave Z
Thanks. I had looked at the article although one person here thought the the rear was aluminum on '61s and '62s. Richard is a real craftsman where I'm just an amateur.
If the top installer pushes my date out any more I'll have to take a look at this. Hopefully he's going to get it done soon.
My '61 rear lower bow is aluminum and I have owned the car since 1974, and know it isn't a repop.
Doug
Doug
Received 1,295 Likes
2022 C1 of the Year Finalist - Unmodified
2021 C1 of the Year Finalist - Unmodified
2019 C1 of Year Finalist (stock)
2016 C1 of Year Finalist
Late to the thread.. but I can confirm my 1-owner, no-changes (early) 61 has an aluminum bow..
SO FUNY - I hardly ever makke mistakes.
Problem solved. Yeah - even my Silvertown tires came today. Wonder what driving on these is going to be like comapered to the radials?
