[C2] Seat Cover "paper clip" source?
Need to get some longer clips since I added a layer of foam to the seat cushions on my '65.
All the usual vendors I've called only stock the entire installation kit, which is usually incorrect for '65's as to the clip lengths.
I know about the zip tie method (my "Plan B"), but would prefer to use the correct clips if a source can be found.
Haven't called Al K. yet, but do plan to.
Thanks, Mike
Thanks, Mike
Received 6,943 Likes
2015 C2 of Year Finalist
No old time upholstery shops near by?
Call Melanie at Al Knoch. If she can't help you, I'm pretty sure Romeo Engineering sells the clips in various sizes, at around $10 a dozen.
lt1user (03-04-2018)
Easy Rhino (12-27-2017)
Fabulous result
Mike Geary (12-24-2017)
Received 3,443 Likes
A tip I learned was to use zip ties first, to pull the material down, and then use the hog rings. The zip ties can then be cut off. This can be a huge help if you don't have enough hands or strength.
That was definitely the least pleasant part of the whole install process.
