[C2] Fuel hose length
Received 2,126 Likes
Is your purpose to meet NCRS specs? If so, do it right. Otherwise, I would make sure to keep it as far away as possible from the exhaust manifold/pipe.
Received 6,521 Likes
C2 of Year Finalist (track prepared) 2019
If it were mine, I'd cut it to whatever length would provide the most gentle curvature to the hose and not permit any kinks to form. Also, from experience, I would slip a coiled spring inside to prevent pump suction from being able to collapse the hose.
Jim
Jim
So what is right? My goal is to replicate GM , which is usually close if not the same as NCRS, but I also want it to function well. If the purchased length is correct, there must be a secret way to route it without kinking. I’m using the correct fitting/lines and pump. Don’t want it too short so engine movement causes an issue either.
Received 1,843 Likes
Fuel line hose is labeled as such. If not labeled, do not use it. Dennis
Received 6,938 Likes
2015 C2 of Year Finalist
The big vendors have that labeled hose in bulk and cut it to length. I’m sure they give you enough and you can trim to fit the car.
