Starting Restoration on the '63
#244
Sweet. I can't tell by the light but what color did you use? Oh, and I hope your happy, but your making it so I just can't put new bushings in everywhere to just go drive my car now.
#247
Received 1,901 Likes
Just let me know if you need them done.
There's a heck of a lot more to doing them then I figured. Fortunately, my friend has done so many, I think he could do them in his sleep.
Pat
Pat
silver837 (04-19-2018)
#248
ptjsk (04-18-2018)
#249
Received 4,583 Likes
C1 of Year Finalist (appearance mods) 2019
You do nice work Pat. .....I bet your 62 is getting jealous with all the attention the new kid is getting.
Hard to believe when you look at them they're only a year apart huh?
ptjsk (04-24-2018)
#252
Looking good Pat. If you keep this pace up you'll be done so fast you will have to go find another one.
ptjsk (04-24-2018)
ptjsk (04-24-2018)
#254
Pat,
If you did not use the original bolt, make sure the center bolt head in the rear spring is thin enough to fit up inside the rear housing without interference.
A few years ago I used a liner kit and new center bolt on a rear spring and the bolt head was so tall it would have cracked the rear housing when tighened.
#255
Received 5,009 Likes
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21-'22-'23-'24
Very impressive!
ptjsk (04-24-2018)
#256
Pat,
Yea, I did have to replace the original pin/bolt.
The height wasn't the problem. The diameter of the bolt head wouldn't fit up into the housing. I just ground it into the "round" shape much like the original was.
Thanks,
Pat
#258
The brake lines and fuel lines finally arrived, so I spent the day installing them.
Pretty amazed at how accurate the bends were. I had kept the old one's to compare, and the new ones were very close.
Broke out all the old clamps, sandblasted & cleaned. Then painted and prepared for installation.
They all turned out pretty good.
Motor is getting decked (while keeping the original number's pad), and all motor parts have arrived. All items getting balanced, and prepared for assembly.
Pat
Pat
silver837 (04-29-2018)
#260
Very nice Pat. You are doing a great job.
ptjsk (04-28-2018)
