Starting Restoration on the '63
#401
Received 1,901 Likes
Finished the 4th prime and 4th blocking. Used tape line to ensure edges are straight and sharp.
Now onto the firewall paint.
Pat
#402
Lookin Good Pat! I remember when that car was on Craigslist about a year to year and a half ago up here in Nor Cal or was it central Cali? I showed it to my wife and told her we need another. Glad you got a hold of it and are making it right.
ptjsk (11-03-2018)
#403
This one was on this Corvette Forum, in the for sale section. It was located in Clovis. I think it was March, or April of 2017 when I picked it up.
Pat
#404
Just wanted to thank you for a delightful, two-coffee-mug morning read of this journey. Great story of skill and persistence. Nice way to watch the sun come up. All the best Pat. Impressive!
ptjsk (11-03-2018)
USMC 0802 (11-04-2018)
ptjsk (11-04-2018)
#407
As close to bubbafied as I'm going to get.
I had to open up the exhaust manifold to a 7/16" to get good threads.
so with a drill and a grinding wheel, I narrowed down a bolt, then threaded it to 3/8" x 16 thread count.
what the heck.....it works!
Pat
Pat
#408
Much closer to Einstein than Bubba!
#410
Very nice Pat. Won’t be long.
ptjsk (11-09-2018)
#411
USMC
Looks great, Pat.
I spy a MagnaFlow Corvette Central exhaust system...Have the same unit on my ‘66 and it sounds awesome at 5800 RPM!
Are your arms and shoulders smoke checked from sanding?
ptjsk (11-09-2018)
#412
I had a problem getting my CC exhaust pipes to fit on the manifold without squeezing one side of the gasket. I ended up modify that end for a square fit on the donut gasket.. Have you installed the starter yet. 2 1/2" pipe gets close to starter but will work.
ptjsk (11-09-2018)
#413
That sanding and blocking is a lot of fun....NOT! I have the body done, but still have the doors, hood and deck lid to do. I'll get the body back onto the frame, and it will free up some of my shop. Then I'll work on mounting, gaps, and all those good things.
I did go with Corvette Central, but ended up going with the off road exhaust system. Hope it sounds good!
Pat
#414
Yea, I too had a problem getting the pipe to fit correctly up under the manifolds. Both sides were bent a bit too much. If you look closely at the pipe, you can see where I heated it up and pulled the bend back out of it a bit. I had to do both sides, but it worked out good.
Supposed to get a starter tomorrow, or over the week-end. Was hoping to find an original '63 starter, but it looks like I'm going to have to go with something else that will work.
Pat
#415
Pat,
You can use a thread sert and repair the exhaust manifold threads so you can use the correct studs, give that some thought before you put the body back on.
From the factory, the exhaust pipes are supposed to have an extension which sits inside the pipe and captures the donut and centers itself inside the exhaust manifold (both sides). When assembled correctly the heat riser will open unobstructed, do some internet on it, most aftermarket don't include it.
Looks great!!
Looks great!!
#416
Pat,
Looks great!!
Looks great!!
Pat
#417
Everything is looking great Pat. I hope you are well removed or at least safe from the fires.
ptjsk (11-10-2018)
#419
Received 5,554 Likes
Pat, looking good! You are flying through this project. Is the body paint going to be the long pole in the tent?
ptjsk (11-10-2018)
