1956 trunk color
1956 trunk color
Does anyone know the correct color to be used in my 1956 trunk? It's a white car with red interior. Some info online indicates the trunk should all be painted red like the interior instead of white like the body color, with a red mat and maybe a black liner across the front of the trunk. Does that sound correct? Also does anyone know whether the spare tire should be a whitewall like the tires on the car or just a blackwall? Same for the wheel, red like the others or just black?
lonestar56 (12-28-2017)
Thanks Donald. That's what I'll do then, paint it all red. And a red mat sounds right then. How about the color of the liner across the front of the trunk? Should it be painted red too or left black the way it comes from the supplier? I've seen it both ways in photos online.
Donald is correct on all counts. The spare should match the other four and the wheel would be painted red. Be sure when you paint your wheels that you paint the back of the black and when you spray the red, let it blow through to the backside onto the black. Don't touch up the black, just let the red blow through show. This is of course if you are trying to reproduce the original factory look.
Received 1,857 Likes
Received 3,769 Likes
2023 C1 of the Year Finalist - Modified
2015 C1 of the Year Finalist
2020 Corvette of the Year Finalist (track prepared))
2019 C1 of Year Finalist (track prepared)
The NCRS Judging manual is not specific about the type of paint finish in the trunk, it only says that it should match the interior color. The paint in my trunk ('57) is original, and it has a semi-gloss finish... not gloss. Most likely it was shot with lacquer and not buffed. My trunk divider has been replaced, and it is somewhere between a flat and semi-gloss finish.
And the spare goes face down in the tub, and the jack sits inside the back of the rim and the trunk board. Those are easy to make if you don't have one.
